Old 06-25-2007, 10:53 PM
ali203joe is on a distinguished road
Exclamation VF 0 Spindle problems
Just had my VF0 give me a bunch of trouble. As it goes to up to speed (3000 rpm) it seems to take a longer time to get up to rpm. and as it comes back down from rpm it errors out and gives a spindle overheating, overload error....ect It also seems to make a hollow cluck noises when it gains rpm and again when it slows back down. please help
Old 06-26-2007, 12:20 AM
HuFlungDung's Avatar
Moderator
Start with the basics. Can you revolve the spindle readily by hand?
Does this machine have a gearbox?
Did it make the noise while running normally at 3000 rpm, or did it only begin making the noise after starting up?
Old 06-26-2007, 01:01 AM
It still revolves. It has a gear box and it did during start up
Old 06-26-2007, 09:14 AM
HAILINHAAS is on a distinguished road
VF-0's don't have gearbox. VF-1B or VF-2B has gearbox.
Your delta/wye switch in the control cabinet could of gone bad.
Old 06-26-2007, 12:00 PM
It is a 2 speed, thought it was controlled by a gear box but may be something else
Old 06-26-2007, 05:17 PM
could this possibly be spindle bearings
Old 06-26-2007, 05:20 PM
Turn the spindle by hand with E-stop on. If it moves freely .. I doubt it's bearings.
Fadal Spindle Problems? TurtleRacing Fadal 12 08-25-2007 10:11 AM
Fanuc 3tc spindle problems R.thayer Fanuc 22 04-14-2007 04:15 AM
spindle problems IeatSteel Bridgeport and Hardinge Mills 3 06-13-2006 02:23 PM
15XT Spindle Driver Problems integral Fadal 4 08-22-2005 03:25 PM
spindle problems hofer Machine Problems, Solutions , Wireless DNC, serial port 4 02-07-2005 01:34 PM
