#14
| get an electricion to megger the z axis cable. if there is a brake in the insulation it can blow the card and this can damage the vector drive. If the spindle drive is braking when an axis card blows it could damage the vector drive.. a chance in a million.. but it could happen |
#17
| I would check the Ohms on your regen box .. the black and white cables .. should be around 5.6 .. also there should be three regens for the 15/20 HP vector drive and four for the 30/40 vector drive ... (stove top burners) |
#22
| 070625-1618 EST USA On our 2000 SL20 the resistors look like electric range top elements. On our VF0, also a 2000 machine, I could not look in the box without a ladder. So I did not look. But the resistors are different. . |
#23
| Totally different. Depending on what spindle drive you have the ohms readings will be different. I through that out there because I've seen where a bad regen will destroy other componets. It seems you have something going on. The Z-axis .. does it have the counterbalance tanks on the side of the column. Make sure its working correctly, and not putting a strenuous load on your Z-axis motor .. Check your DC buss periodically and make sure its within 310 to 360V ... your incoming power needs to be stable. If your incoming power is an issue you can get an external transformer that could help. Troubleshooting .. ahhh .. gotta love it. |
| X-Axis Blowing fuses | Thom45 | Commercial CNC Wood Routers | 0 | 02-21-2007 01:33 PM |
| Fuse Blowing! Please Help | audioandy1762 | Gecko Drives | 6 | 01-22-2007 03:52 PM |
| A Little Help Before I Run the Risk Of Blowing This Up | silver | General Electronics Discussion | 1 | 12-16-2006 10:34 PM |
| Blowing fuses | kaderick | General Electronics Discussion | 2 | 12-05-2006 11:34 AM |
| Blowing the fuses | rocks101 | Hobbycnc (Products) | 2 | 02-26-2005 03:00 AM |
