Old 06-20-2007, 04:56 PM
Matt@RFR is on a distinguished road
New VF-2SS wiring question
Well, my new machine has been sitting on my garage floor for roughly 30 minutes!
I'm trying to get the thing wired today so I can have the techs come and do their thing before the weekend and Sellway is slow.
Does this thing need a neutral going to the main cabinet? I can't find that information anywhere.
Old 06-20-2007, 05:47 PM
No, just the three phases onto the terminal block above the main breaker. And a ground to the grounding terminal near them.
The Haas machines do not use a neutral line.
Old 06-20-2007, 05:49 PM
What would I do without you Geof?! Thanks!
Old 06-22-2007, 12:41 AM
JMFabrications is on a distinguished road
Quick question sorta related.....what size breaker do you guys use with the VF2, I just purchased a 2002 model and it will be here next week, just trying to get the line ready so I can power it up right away. It has the 20HP motor on it. I think I read the amp draw was 40 max or something.........
Thanks,
Jim
JM Fab
Old 06-22-2007, 09:03 AM
Thanks,
Jim
JM Fab
My electrican installed 50amp panel breakers for my VF2s and used 6 gauge wire.
Old 06-25-2007, 05:10 PM
gar gar is offline
gar is on a distinguished road
070625-1602 EST USA
JMF:
We use 40 A Sq-D QO breakers for our VF-3s and #6 wire. Never have tripped one from the machine operation. However, we do not run high spindle loads.
Our total run from the main breaker box to the furthest machine is about 75 ft for the cable run. Our leg-to-leg voltage is usually about 246 V.
Wiring question TSJ Servo Motors and Drives 4 05-15-2007 02:20 PM
Transformer wiring question Bimmerkc1 General Electronics Discussion 3 01-13-2007 08:41 AM
Wiring Question elogicca General Electronics Discussion 6 12-26-2006 09:22 PM
Wiring Question The Wizard General Electronics Discussion 17 01-04-2005 01:11 PM
Wiring Question tjstraz General Electronics Discussion 1 07-30-2004 11:35 AM
