Hey everyone, I just purchased a Haas VM2, and am doing some shopping for cutting fluid right now. I am pretty new to the selection of cutting fluid, so I could use some input from some fellow haas users. I want something that wont cause too much skin irritation, and will be relatively low maintenence. I have done some reading up on various cutting fluids and have had some reccomendations, but am still shopping for more input. I am not too familiar with some of the names, but at my last job, we used this milky blueish fluid, and now at Caterpillar we use this clear fluid. I was also reccomended to use Castrol Syntilo 9926. Any thoughts? Thanks in advance. Albert |
| We use Blaser Swisslube Blasocut 2000. Been using it for about 5 years. We put in our bed mills, lathes and Fogbusters. Excellent product, no skin irritation yet(10 employees). Lasts a long time with no smell. Milky blue brown color. Mixes with water. Fanastic product. We went through 7 others before we found this. |
| I have been using Kleen-Kool 777 for about 7 years now. I just cant find a downside. Easy to mix, no skin irritation, never grows anything. I tap a lot of #6,8,10 screws in alum...no problem. http://www.doallsawing.com/cutting_f...hetic%20Fluids |
| USE THE CASTROL I use Syntilo 9954 and switched from Hangsterfers s500. The result was much less coolant maintainence, little or no coolant "rot", MUCH less smell, better part finishes, easier cleanup and at least with me, no skin problems. Just use de ionized/ de mineralized water. Water run thru one of those carwash filters works great. All the minerals that cause spots on your car are removed. If keep adding just tap water to replace water from evap you eventually will have the water hardness in your coolant go through the roof and crap will start building up all thru the machine. |
#11
Take a look at Trimsol E206 It works for almost any type of cutting. It's a "green" product, you can pour it down a sewer drain It's non toxic you could drink the stuff without getting killed. And you can mix it to different consentrations for different types of work. thin for alu. and plastic, thicker for high pressure cuts like SS and tool steels. And very few problems with smelly coolent. sorry about the spelling |
#12
| thanks for the replies guys, I ended up going with the Hangsterfers S500. Good results so far, but I claim to be no expert, and my experience with other coolants is slim to nil. No skin rashes, easy to maintain, has that "I'm printing money" smell |
| Cutting fluid for aluminum? | Ben | General Metal Working Machines | 7 | 11-17-2011 10:03 AM |
| Cutting fluid recommendations for flood cooling? | VTX | Benchtop Machines | 2 | 04-10-2007 12:09 AM |
| Window cleaner as cutting fluid | voxelman | General Metalwork Discussion | 12 | 05-14-2006 02:03 AM |
| Mist oiler cutting fluid | balsaman | General Metalwork Discussion | 4 | 11-04-2005 10:01 PM |
| Cutting fluid that doesn't smell? | sendkeys | General Metal Working Machines | 5 | 09-09-2004 01:29 PM |
