Old 06-18-2007, 10:18 AM
elaganis is on a distinguished road
USB ports on New Mills
Does anyone know where I can get the list of approved mass storage devices which work with the USB port on the haas mills? I'm able to get one of my machines (VM3) to read from a flash stick but not the other one (VF2SS) and neither one will read from a USB external hard drive which is my goal.
-E
Old 06-18-2007, 10:42 AM
HuFlungDung's Avatar
Moderator
What operating system is Haas using on the new machines? Unless it were windows, I can only guess that they need to write special DOS drivers to make USB work with certain hardware, maybe even with specific hardware? Just my WAG as to why plug and play would not really work on random USB devices plugged in to their m/b.
Old 06-18-2007, 12:12 PM
nervis1 is on a distinguished road
I've used at least 10 different brands of USB thumb drives on mine never had any problems. I even used a 4 gig Sony pocket drive. The port will provide power to the drive but I don't know how much. Never tried a portable HDD.
I would not see a need for a HDD just use a big thumb drive. I've seen 4 gig, 8 gig you really going to fill one of those up with G code?
Old 06-18-2007, 12:20 PM
daleman is on a distinguished road
we use an external harddrive with a usb 2.0 connection it works fine you should not be having any problems with the one you have got
Old 06-18-2007, 01:47 PM
Can I ask what model hard drive you are using? These machine are sensitive to certain USB devices. The maxtor 256G external hard drive I plugged in did NOT work on our 10 day old VF2SS.
Old 06-18-2007, 03:24 PM
we use a SEAGATE ST3320620U2-RK - 3.5" 320GB EXTERNAL HARD DRIVE we connected to our pc first and transfered some haas files to and away we went this used on our vf2ss , and our 3 super mini mills
Old 06-18-2007, 09:55 PM
CJH CJH is offline
CJH is on a distinguished road
We have an '03 TM-1 in our shop with the USB and 20gig Harddrive on it and have only a few minor glitches with it. One thing I would recommend would be to use good brand name USD drives (sony, scandisk, etc.) It seems to hiccup a bit if we are using a cheapie. Also there has been a few occasions where I walked out the door at night with my USB in my pocket and forgot the next day, so I just took a card reader, and one of the memory cards from our digital cameras and used that and didn't have a problem.
You may have a faulty USB port or USB stick, just some thoughts.
CJH
Old 06-23-2007, 06:58 AM
serviceman's Avatar
serviceman is on a distinguished road
erase everything on the usb key and try to write from the haas to the key some usb drives put programs on the keys and there was a software problem with the earlier usb ports. you have to make sure that you can view hidden files on your computer
Old 06-25-2007, 11:25 PM
hairball is on a distinguished road
Must be something wrong with my machine because I’ve had nothing but problems with my USB. I almost with I had the floppy.
Old 06-26-2007, 09:46 AM
I tried 4 different USB flash drives before I got one to work. Call up Haas and get the list of tested devices which work. If they don't work they should replace it.
  #11   Ban this user!
Old 10-22-2008, 09:33 PM
Moxo is on a distinguished road
Check format type!!!!!
  #12   Ban this user!
Old 10-26-2008, 10:17 AM
fourperf is on a distinguished road
When I first got my VF2 (1 year ago) only 1 usb stick drive worked on the machine. It was the one that the tech owned. I bought 4 or 5 new ones (including the exact same brand and model as the tech`s) to try but they didnt work either, only that one stick worked. The VFO replaced the main board and everything started working fine. Very weird I thought but now its fine. Here is the thread
USB port
Mark
More on ports and pins andrewbishop66 Mach Software (ArtSoft software) 2 03-08-2007 08:05 PM
SPC Ports What are your Use? SMW Precision Calibration & Measurement 1 07-31-2006 04:46 PM
ports and pins planescott Stepper Motors and Drives 5 03-25-2006 12:57 AM
Parallel ports itsme Computers and Networking 8 09-30-2005 09:20 PM
3.3 V vs. 5 V TTL on parallel ports HansM Machine Problems, Solutions , Wireless DNC, serial port 4 07-28-2005 03:28 PM
