| O.K. I now know what VQC menu is, I also have fiound the O09XXXX files. What I can't figure is how to turn the probe on/off and the g code program required to find the center of an O.D. and zero out at that loc. |
| And if you press edit, then program conversational 3 times, if you have the templates on your machine you should be able to find one that says something like "Haas Mill VCQ Probe Inch/MM" Once you find those templates, you should see one that does exactly what you're asking. |
| One piece of advise when probing, if you have a probe loaded, it should only be moved to peliminary position by what Renishaw refer to as a protected move, which is essentially an anti-collision move. IOW you may program a G0 that could cause the probe to collide with a part or jig etc. The protected move is usually a macro that has the G31 in it. If no collision occurs, then it arrives at the desired position, otherwise it will stop before any damage. There should be a macro that is labeled accordingly. Al.
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I opened the editor today and there are no references to any probe cycles. It shows g73 High speed peck,g81 g82,g83,g84,bolt hole patterns ,etc. I did unlock the 9xxxx programs and by calling one up was able to start the probe, but I'm thinking there must be some template or g code that needs to be invoked to get the job done. The operators manual doesn't show me much along these lines. Thanx in advance for any helpful input. Phil |
#10
| When you select the correct program you will get 4 choices: Spindle Probe 1-9 Spindle Probe 10-18 Tool Setting Calibrate Probe. What you would be looking for would be in one of the first two groups. |
#11
| O.K. I tried edit/prg conv 3 times then F2 with the same results as before. It brought up the srceen for g73,g81, etc. no reference to probe cycles or anything else. I don't see anything called VQCPSV1.8 anywhere on the control panel, in the manual, or on any edit screens. I am begining to think something is missing in the machines software. Phil |
| Hooking a Probe | Tazzer | Hobbycnc (Products) | 1 | 09-11-2006 09:20 PM |
| Probe dia and length | cncuser1 | Digitizing and Laser Digitizing | 0 | 08-13-2006 08:29 PM |
| CMM probe | sab | Open Source Controller Boards | 3 | 03-07-2006 05:37 AM |
| DIY Non contact probe? | Jayson | Digitizing and Laser Digitizing | 0 | 03-01-2006 07:55 AM |
| Probe Cost | jhwatts | Digitizing and Laser Digitizing | 17 | 01-20-2006 12:08 AM |
