Old 06-14-2007, 06:04 PM
stang5197 is on a distinguished road
VF0E Macro Problem
Trying to load a simple problem (via floppy disk) and it loads but says Macros locked.
Ok machine doesn't have the macro option but where is the macro in the program? It is a simple program generated from M.C.
The machine is a '01 Haas VF0E
I am not very familiar with Macros but can't see anything wrong with the program.
Here is the complete program:
O9886( CAMB )
( DATE=DD-MM-YY - 14-06-07 TIME=HH:MM - 16:53 )
( MCX FILE - C:\DOCUMENTS AND SETTINGS\\MY DOCUMENTS\MacroProblem)
( NC FILE - F:\CAMB.NC )
( MATERIAL - ALUMINUM INCH - 2024 )
( T7 | 1/2 FLAT ENDMILL | H7 )
( T10 | 3/8 FLAT ENDMILL | H10 )
N100 G20
N110 G0 G17 G40 G49 G80 G90
N120 T7 M6
N130 G0 G90 G54 X1.75 Y0. A0. S6000 M3
N140 G43 H7 Z1.
N150 M8
N160 Z.1
N170 G1 Z-.245 F6.4
N180 G3 X0. Y1.75 I-1.75 J0. F110.
N190 X-1.75 Y0. I0. J-1.75
N200 X0. Y-1.75 I1.75 J0.
N210 X1.75 Y0. I0. J1.75
N220 G1 Z-.49 F6.4
N230 G3 X0. Y1.75 I-1.75 J0. F110.
N240 X-1.75 Y0. I0. J-1.75
N250 X0. Y-1.75 I1.75 J0.
N260 X1.75 Y0. I0. J1.75
N270 G0 Z1.
N280 M5
N290 G91 G28 Z0. M9
N300 A0.
N310 M01
The folllowing program on the same floppy loads and runs fine with no problem, so it is not the floppy:
O02311( AuxilaryFaceThickness )
( DATE=DD-MM-YY - 14-05-07 TIME=HH:MM - 20:11 )
( MCX FILE - T )
( NC FILE - A:\AFACE.NC )
( OffSet From V-Block On Vise)
( MATERIAL - ALUMINUM INCH - 6061 )
( T1 | 1 INCH FLAT ENDMILL | H1 )
N5000 G20
N5010 G0 G17 G40 G49 G80 G90
N5020 T1 M6
N5030 G0 G90 G54 X-1.8165 Y-2.2999 A0. S6000 M3
N5040 G43 H1 Z2.
N5050 M8
N5060 Z.65
N5070 G1 Z.26 F6.4
N5080 X1.7665 F200.
N5090 X2.3898
N5100 G3 X2.7184 Y-1.9713 I0. J.3286
N5110 X2.3898 Y-1.6428 I-.3286 J0.
N5120 G1 X-2.3898
N5130 X-2.7274
N5140 G2 X-3.056 Y-1.3142 I0. J.3286
N5150 X-2.7274 Y-.9857 I.3286 J0.
N5160 G1 X2.7274
N5170 X2.8813
N5180 G3 X3.2099 Y-.6571 I0. J.3286
N5190 X2.8813 Y-.3286 I-.3286 J0.
N5200 G1 X-2.8813
N5210 G2 X-3.2099 Y0. I0. J.3286
N5220 X-2.8813 Y.3286 I.3286 J0.
N5230 G1 X2.8813
N5240 G3 X3.2098 Y.6571 I0. J.3285
N5250 X2.8813 Y.9857 I-.3285 J0.
N5260 G1 X-2.7274
N5270 G2 X-3.0559 Y1.3142 I0. J.3285
N5280 X-2.7274 Y1.6428 I.3285 J0.
N5290 G1 X2.3898
N5300 G3 X2.7183 Y1.9713 I0. J.3285
N5310 X2.3898 Y2.2999 I-.3285 J0.
N5320 G1 X-1.8165
N5330 G0 Z2.
N5340 M5
N5350 G91 G28 Z0. M9
N5360 G28 X0. Y0. A0.
N5370 M30
I have rebooted the machine, resaved the program a couple times, but for some reason it thinks there is a macro somewhere.
Any help?
Old 06-14-2007, 06:34 PM
WITOMCIO is on a distinguished road
Change your program number O9886( CAMB ) to O06886 . Programs starting with 9XXX are usually reserved for macro's.
M6 macro ben_heinman General CNC (Mill and Lathe) Control Software (NC) 2 03-30-2007 01:37 PM
M6 Macro ben_heinman Fanuc 5 03-29-2007 05:02 PM
Macro B jorgehrr G-Code Programing 2 01-31-2007 03:23 PM
what is a macro? ljoe1969 Autodesk Software (Autocad, Inventor etc) 3 07-12-2006 09:12 AM
One More Macro ? 16I Bluesman General CNC (Mill and Lathe) Control Software (NC) 4 02-07-2006 06:06 PM
