Hi guys, I canīt send and receive program with Cimco edit, i set the same parameters that the control. Actually use Hyperterminal and i want change this for Cimco. Exists a configuration for Haas lathe? Thanks for your time, Alain |
| 070613-1942 EST USA alain aleman: You did not specify your settings. I will suggest the following as a starter: At HAAS 9600 baud rate, 7 data bits, 1 stop bit, even parity, software handshake. Use a cable with a 25 pin male connector at HAAS and a 9 pin cable female at the PC. Do not use a USB to RS232, but use a PCI card in the mother board if there is no internal RS232. Connect pin 2 to pin 2, pin 3 to pin 3, pin 7 on the 25 pin connector to pin 5 on the 9 pin connector. Pin 1 on the 25 pin connector to the shield. This is the only shield connection. Make a short cable, like 10 ft, with these connections. At the PC, assuming windows like XP, go to the device manager and disable the FIFO for the COM port you are using. In CIMCO Edit select TRANSMISSON, DNC SETUP, pick a machine, use standard generic protocol, generic ISO, and pick setup. Now set the parameters --- your COM port, 9600 baud rate, 7 data bits, 1 stop bit, even parity, software handshake, do not enable DTR, RTS, use \17 for Xon, \19 for Xoff. The defaults for RECEIVE and TRANSMIT are probably OK. Pick OK to save your changes. Use Send File and Receive File for communication. Put HAAS in receive first, then initiate send at the PC. Or Put PC in Receive File, then initiate send at HAAS. . |
| Issues with VMC20 using CIMCO Edit | SeriousMach1 | General CNC (Mill and Lathe) Control Software (NC) | 1 | 03-29-2007 05:48 PM |
| Drip feeding to a Haas with Cimco Edit | BMackinnon | Haas Mills | 2 | 11-14-2006 08:02 PM |
| Fanuc OT - Cimco | stealth03ss | Machine Problems, Solutions , Wireless DNC, serial port | 0 | 09-11-2006 12:45 PM |
| DNC between FANUC 16 and CIMCO dnc Max | Ninus | Machine Problems, Solutions , Wireless DNC, serial port | 5 | 02-13-2006 10:32 AM |
| Cost of Cimco DNC Max 4 and Cimco Edit | CBNDude | CNCzone Club House | 5 | 03-10-2005 03:44 PM |
