Old 06-13-2007, 01:52 PM
jprobst is on a distinguished road
countersink 304 stainless
any6 suggestions on a good countersinking bit to counter a 5/16" flat head in 304 stainless?
Old 06-13-2007, 02:23 PM
rbest27 is on a distinguished road
82 deg carbide c'sink will work fine if you don't have one high speed will work also
Old 06-13-2007, 02:34 PM
DSL PWR is on a distinguished road
Just remember to use a high feed and DO NOT PECK!!!
On all equipment there are 2 levers...
Lever "A", and Lever F'in "B"
Old 06-13-2007, 02:38 PM
Don't peck? thats what i've been doing with a hss countersink and one last for about 60 holes and the other lasted one hole, i'm trying to find a bit in a catalogue that will last the remainder of the job, my boss is already flipping on the two bits, so i shouldn't peck? right now i have it going .3 deep at .020 pecks at 420 rpm, this wrong?
Old 06-13-2007, 02:40 PM
i also have it going 1 i.p.m
Old 06-13-2007, 09:28 PM
Newby2 is on a distinguished road
seems your speed is a bit to fast for stainless. try 150- 200 RPM and as others have said, high feed, no pecking
Steve
Old 06-13-2007, 11:19 PM
gizmo_454 is on a distinguished road
150 to 200 rpm? That sounds a bit on the slow side. We run jobs on our 1940's screw machines drilling holes bigger than that in 304 at 500+ RPM. I would think that your 420 is all right if the outside diameter of the c-sink is 5/16. If it's for a 5/16 flat head cap screw, it may be too fast. The peck sounds like the main problem. 300 series stainless work hardens, so unless you continually remove material, you will work harden it. So the next time the tool comes into contact, it will either break, or cause it to wear prematurely.
When it comes to stainless, it seems people will more than likely under-do something in fear of breaking something. Unfortunately, it causes more harm than good. Obviously, you don't want to go the other way either. Stainless is somewhat picky that way, don't you think?
Good luck!
Old 06-14-2007, 12:08 AM
Gizmo is correct about 300 series stainless being a RPITA. But it is interesting to note that 303 machines much better than 304.
Also, as with any machineing job, the tools that are used can make the difference between a profit and a loss. I did on job where the boss handed me a box of tools to make the parts with. The result was a 66% scrap rate. I talked him into a carbide bullet drill and the scrap rate dropped to less than 3%.
There are times when, in this day and age of advanced machining methods, some of the bosses just don't want to grow up and listen to those that make them the money!
Steve
Old 06-14-2007, 06:38 AM
joecnc1234 is on a distinguished road
If you're having that much of a problem rough c-sink than finish the depth with another tool. The feeds and speeds don't seem that far off other than the fact you are probably burning the tool up at 1 ipm.
Joe
Old 06-14-2007, 10:05 AM
PBMW is on a distinguished road
I have a job where I make 15k parts a month. They have two countersunk .411 holes. 82 deg. this is in 304.
I got tired of buying carbide countersinks. I now drill and interpolate the minor hole dia. (It's close tol) then I interpolate the ocuntersink with a carbide countersink. I stopped plunging them as the chips would turn into a rats nest where the operator needed to stop the machine to clear the chips ftom the cutter. I'm doing 40 pcs at a time. I tried pecking and that worked pretty well. I was getting about 500 holes out of a countersink. I was running 200sfm and .006 per rev to plunge. I started interpolating the countersinks and the cycle time went down a bunch over pecking and the tool life went to over 6k holes.
Worked for me.
  #11   Ban this user!
Old 06-14-2007, 11:29 AM
this might be a dumb question, but what does interpolate mean and how do i do it?
  #12   Ban this user!
Old 06-15-2007, 03:45 AM
lol
304 stainless on vf-2 jprobst Haas Mills 6 06-12-2007 08:28 PM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 06:46 AM
Stainless Or Steel 69owb Mechanical Calculations/Engineering Design 5 10-03-2006 02:43 PM
Cutting Stainless Jedi General Metalwork Discussion 5 06-09-2006 09:10 PM
Stainless 304 pauls General Metalwork Discussion 11 06-04-2005 04:50 AM
