  #13   Ban this user!
Old 06-15-2007, 08:42 AM
jprobst is on a distinguished road
Originally Posted by joecnc1234 View Post
lol
hey thanks for the support man
  #14   Ban this user!
Old 06-15-2007, 09:26 AM
rbest27 is on a distinguished road
what type of tool are you using first of all. High speed or carbide? I've got c'sink's that I've had in my tool box for years. If it's a high speed c'sink try 50 surface feet calculated at the max diameter of the c'sink. My best results have always been just plunging it right in...no pecking. I wouldn't run too slow...you want a nice chip coming off the tool that way there you don't get a rat's nest. Carbide you can run a bit faster...chip load on either one I would estimate at about .005 per rev.
As for the boss freaking out, that's what they do. Sounds like your shop has limited experience with stainless so you'll have some growing pains. Countersinks don't cost that much that he should be freaking out.
  #15   Ban this user!
Old 06-15-2007, 09:47 AM
AMW's Avatar
AMW AMW is offline
AMW is on a distinguished road
Hmmmm how can i put this??????
ok,ok: program a circle= interpolate= go from one pole to the other pole=make a circle
I think
LOL me too
AMW
  #16   Ban this user!
Old 06-15-2007, 10:39 AM
well the customer came by yesterday and needed his parts this morning, so after hours i broke my last muliflute countersink, thought i was dead in the water, then i found a single flute hss 3/4" countersink i ran it at 250 rpm with a plunge rate of .5 and it ran very well, got the job done, billed customer double for the rush and didn't break anymore bits, so thank you all for your help, as fas as interpolate question, i'm fairly new at this vmc stuff so i'm gonna ask any question i can, no matter how stupid the question is, not only am i the only programmer in the shop, i run the shop to and don't have the time i need to sit down and learn about this stuff, so i learn as i go and ask what some might feel as a stupid question.
  #17   Ban this user!
Old 06-16-2007, 08:45 AM
PBMW is on a distinguished road
Jprobst
To interpolate is to consider the hole as a profile and drive the tool around the ID to generate the angled countersink.
  #18   Ban this user!
Old 06-16-2007, 03:01 PM
thank you
Old 06-16-2007, 03:20 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
with using interpolation you should be able to accomplish a consistantly clean surface finish , i would cut it in two passes or
you could helix in so you can save from any air cutting and prevent any lead in and lead out marks
304 stainless on vf-2 jprobst Haas Mills 6 06-12-2007 07:28 PM
Steel or Stainless tool_man Casting Metals 2 10-29-2006 05:46 AM
Stainless Or Steel 69owb Mechanical Calculations/Engineering Design 5 10-03-2006 01:43 PM
Cutting Stainless Jedi General Metalwork Discussion 5 06-09-2006 08:10 PM
Stainless 304 pauls General Metalwork Discussion 11 06-04-2005 03:50 AM
