Old 06-11-2007, 11:27 AM
Matt@RFR is on a distinguished road
VF-2: Will Kurt D688 fit?
Hey guys, I'm buying a VF-2SS and need to buy my vices, but can't get a straight answer out of my dealer about whether or now Kurt's longer 6" vice (D688) will fit on the table without running into the sheetmetal. I'd prefer to bolt the vice down to the center T-slot.
Old 06-11-2007, 11:51 AM
You will have no problem. The vise can hang out almost one inch behind the table and still be clear of the way covers. Mounted to the center tee slot the D688 is back about an inch from the edge of the table. You can easily mount the Kurt 6" Duolock vise on the VF2.
And if you are running multiple parts think hard about getting the Duolock; it is about twice the price but you can recover that in a short time when doing twice as many parts per cycle.
Old 06-11-2007, 11:59 AM
Thanks Geof. I was more concerned with the overhang off the front of the table, which by my math, is about 4 1/8" plus the spud for the vice handle.
I'm going to atleast start out with two D688's because some of the work I've been looking at is bigger flat bar parts (1"x8"x28" for example) that I'll need to hold over two vices, but I appreciate the advice and will look into it once this machine is on its feet.
Old 06-11-2007, 12:10 PM
Thanks Geof. I was more concerned with the overhang off the front of the table, which by my math, is about 4 1/8" plus the spud for the vice handle......
At the front the hex drive end comes up about one inch shy of the edge of the drip tray on the table.
You need to extend the vise handle unless you enjoy smashed knuckles.
Old 06-11-2007, 12:17 PM
nervis1 is on a distinguished road
I took off that drip table, got tired of not being able to use the long handles.
Kurt 688s fit fine you can get three on there easy.
Old 06-11-2007, 12:19 PM
Perfect, thanks a bunch guys. The machine should be leaving the factory in three days!
Old 06-11-2007, 12:38 PM
I did the alternate and extended the shaft on the vise handle to reach out the door. This has the added advantage that the door cannot be closed with the handle still on the vise.
Kurt DL600 Double Vise Fudd General Metal Working Machines 4 08-06-2010 01:41 PM
kurt vise quality? jed102 Work Fixtures and Hold-Down Solutions 83 04-13-2010 12:05 AM
Which Kurt Power drawbar? acerocket Bridgeport and Hardinge Mills 0 09-14-2006 12:02 PM
Kurt drawbars MrWild Bridgeport and Hardinge Mills 4 07-26-2006 09:58 PM
Which Kurt Vise to get for CNC JMFabrications Work Fixtures and Hold-Down Solutions 21 03-27-2006 12:07 PM
