Old 06-07-2007, 09:00 AM
binzer is on a distinguished road
Haas Indexer hrt610
Is there a way to controll the feed rate when A turns? Right now it just goes off the rapid of the machine?
Old 06-07-2007, 10:30 AM
HuFlungDung's Avatar
Moderator
There is a parameter in the settings (#34) where you input the diameter of the stock. This can be anything you like, but from it, the control will compute the feedrate based on the circumferential distance at that diameter, whenever a pure G01 A command is given. Otherwise, with an XA or ZA or YA interpolated movement, the linear feedrate is "boss" and will control the duration of the movement.
In this manner, ordinary linear Feedrate commands will work with A feed movements.
hardinge / haas indexer parameter 30 ? jim007 Bridgeport and Hardinge Mills 0 02-19-2007 03:13 PM
Haas S5C Indexer motor Andrew M. Haas Mills 11 09-02-2006 09:57 AM
haas indexer serial protocol ? pit202 Haas Mills 0 02-28-2006 12:08 PM
Haas indexer servo motor help. Andrew M. Servo Motors and Drives 1 01-21-2006 06:26 PM
HAAS Indexer Prodramming / Control CAMmando Haas Mills 8 06-10-2003 10:22 AM
