You could wire a relay in to your coolant pump circuit disconnect the coolant pump and use a step down transformer to run the 24v solenoid. Than you could use m8/m9 to turn the air off and on. But Im sure haas has some extra m functions that you could plug into to achieve the same thing. Give them a call I've found their phone service excellent.
Joe
LinkBack URL
About LinkBacks
