Old 05-12-2007, 08:19 AM
JerryH is on a distinguished road
SUper Mini Startup Problem
So I go to power up the machine this morning, and all I get from the control is a steady beep. Checked incoming power and all seems fine. Could there be a blown fuse in the machine somewhere, or is it something worse?
Old 05-12-2007, 09:29 AM
gar gar is offline
gar is on a distinguished road
070512-0926 EST USA
Power down and up several times. If no change in problem, then call HAAS.
Old 05-13-2007, 05:32 AM
daleman is on a distinguished road
how old is your super mini mill
Old 05-13-2007, 09:03 PM
axis is on a distinguished road
is it a beep or a hum that sounds like a beep
Old 05-14-2007, 08:19 AM
The machine is a 2001. The symptom is definitely an intermittent beep, with the spindle load meter spiking along with the beeps. Haas thinks it may be a low voltage power supply?
Old 05-14-2007, 11:22 AM
gar gar is offline
JerryH:
HAAS uses a PC type switching power supply for their processor power. This is near the middle top of the panel. AS with most PC power supplies there are extra leads and connectors. Check the voltages relative to common, which is probably black, these should read +5 V and +12 V. I would expect the +5 to be within +/- 0.1 V relative to 5. The processor board will probably work down to maybe as low as 4.5 V, but almost certainly would work down to 4.75 V.
Relatively recently HAAS has had a batch of bad processors, but a 2001 machine should not fall in that group.
2412s super mini PBMW Sharp CNC 35 10-09-2007 07:37 PM
Startup Problem StormWerkz Fadal 14 03-06-2007 09:57 PM
Hurco BMC 20 startup problem tirebiter Machine Problems, Solutions , Wireless DNC, serial port 3 11-08-2006 04:50 PM
help with super mini mill please daleman Haas Mills 12 08-14-2006 02:32 PM
part for super mini mill daleman Haas Mills 0 05-04-2006 01:03 PM
