Old 05-09-2007, 10:26 AM
jprobst is on a distinguished road
engraving on vf-2
I make these custom sand rail parts for my brother and now he wants to put in his company logo, my question is can i do an engraving using a contour toolpath? and if so can anyone recommend the style of bit to use along with speeds and feeds? we are now doing it on an old manual engraver but i have a 2007 haas vf-2 with 10,000 rpm spindle, so it makes sense to do it when i cut the part, any help in this matter would greatly be appreciated.
Old 05-09-2007, 11:56 AM
ltmquik's Avatar
ltmquik is on a distinguished road
Depending on the size of the logos or lettering we use 1/32" BEMs down to custom ground 0.005" tapered cutters. My guess is you could use a 1/32" BEM.
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 05-09-2007, 12:21 PM
how fast do you go?think i'm gonna try it, i don't see any reason why it wouldn't work
Old 05-09-2007, 12:36 PM
gar gar is offline
gar is on a distinguished road
070509-1220 EST USA
jprobst:
We use a standard engraving cutter with a 0.005" tip.
See
http://www.gravograph.com/usa/Engrav...ng_Cutters.php
Some samples on my web site at www.beta-a2.com
See MISCELLANEOUS PHOTOS page photos P7 (used an end mill), and P9 thru P11 using New Hermes cutter.
(edit)
7500 RPM, our maximum, and maybe 10 IN/MIN in Al.
(end edit)
Old 05-09-2007, 01:33 PM
ltmquik's Avatar
We run about 60ipm 12K rpm about .003"-.005" deep cuts.
Jeff Lange
Old 05-09-2007, 03:22 PM
Loading is on a distinguished road
At school we didn't have any 'fancy' cutters. We just used a #3 center drill. 7500 rpm was our max and we went ~15 IPM with a few thou DOC.
Old 05-09-2007, 03:54 PM
We use standard 90 degree spot drills, 1/8" and 1/4" at depths from 0.003" to 0.020" using up to 60 ipm at 10,000rpm on aluminum and drop the speed to about 6000rpm and 20 ipm on leaded steel.
Engraving on an arc YV600 Haas Mills 15 03-31-2008 12:46 PM
engraving dickiedog CNCzone Club House 0 12-24-2006 04:00 PM
2D engraving itsme General CAM Discussion 9 09-04-2005 07:09 AM
Engraving Hack General CAM Discussion 6 03-25-2005 08:53 AM
Engraving rickpuig DIY-CNC Router Table Machines 1 02-05-2005 10:58 AM
