Old 04-21-2007, 01:35 PM
Vern Smith is on a distinguished road
Mystery drill
I'm hoping someone can identify the drill / router pictured below. It's center cutting and does a great job in carbon filled plactics.
http://i129.photobucket.com/albums/p...sterydrill.jpg
Vern
Old 04-21-2007, 02:26 PM
Your picture is a bit fuzzy (or my eyes are ) but I think I have seen a drill a bit like that for use drilling laminate covered MDF.
Do the cutting edges have a little 'tooth' on the periphery, can't think of any better way to describe it, that means when you are drilling through it breaks through on the periphery before the center?
Old 04-21-2007, 02:41 PM
automizer's Avatar
automizer is on a distinguished road
To me that looks like this here
https://www.onsrud.com/oc/pdf/Specia...iteMilling.pdf
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 04-21-2007, 02:53 PM
cb1 cb1 is offline
cb1 is on a distinguished road
that tool is just a style of router bit, if you need to buy it there will be a
supplier near you who will have 1. any grinding house should be able to make
it, if you can't find 1.
i could make you one today but i'm way up in canada.
i've made those many times.
Old 04-21-2007, 03:15 PM
Sorry about the picture quality. If I use the flash the reflections ruin the clarity so I use a flash light and no flash. The problem with this is the need for a slow exposure speed and I don't have a tripod. I guess I need one of the new digital SLR's with image stabilization.
The bit is designed to break out at the periphery first as Goef asked. When you look directly into the business end of the bit it makes a "Z" pattern. However, the vertical leg of the "Z" is absolutely vertical.
I'll look into the router situation. I imagine most industrial supply houses handle them as well as EM's.
Vern
Mystery Problem IQChallenged CNC Wood Router Project Log 10 07-29-2006 08:00 PM
The G-Code mystery magicaldog OneCNC 3 11-08-2005 12:10 AM
Guess this mystery sound. ynneb CNCzone Club House 18 07-04-2005 07:18 PM
The Mystery of Z offset Swede General Metal Working Machines 10 05-06-2004 12:32 PM
Z axis mystery solved HuFlungDung Machine Problems, Solutions , Wireless DNC, serial port 1 09-09-2003 06:24 PM
