chatter and tools sticking in the machine at times can be caused by the pull studs being excessively over tightened which in turn causes the taper to swell (beleave it or not) , one machine we ve got sticks at times ,and when i remove the stud and retighten it the problem goes away ,some guys i work with far over tighten them , i beleave there is a suggested torque setting with the use of loctite
LinkBack URL
About LinkBacks
