Old 03-28-2007, 08:17 AM
superrat's Avatar
superrat is on a distinguished road
X servo error on tm-1...
so, this morning i turn on the power to my tm-1 -reset, powerup/restart and i get "error 103 x servo error" then i give the connections a visual inspection and nothing seems out of place, and wasn't loose or dirty. i turn the power off and then back on and starts up fine?
my question is, is this the beginning of something bad or is there something i need to be doing?
i had an error on the y axis the other day but it was just the proximity switch had gotten some coolant and a chip on it. (the current pail of valcool is nastier and stickier than the last...)
it just finished the warm up program so i guess i'll keep running it. any insight is appreciated.
--phil
never time to do it right, always time to do it again...
Old 04-14-2007, 03:26 AM
JHamdan78 is on a distinguished road
we have to tm1's, i always get servo errors after i grease them. i usually just run rapids at 50% for about 15mins and then there fine. this could be because i upped the x,y,z rapids up to 600ipm.
Old 04-14-2007, 07:02 AM
gizmo_454 is on a distinguished road
I had this problem too on our Mini Mill. It did it for a couple of days, so I called our HFO. They came out and looked at it and couldn't figure out what was causing it. After playing with connections, trying a different board, even different amps. He put it all back together and it has been fine ever since, with the original running gear back in place. I would say it must be a loose connection somewhere, but who knows where. The service guy was here for about 6 hours trying to figure it out. LOL. Gotta love that. Good thing it was under warranty.
Old 04-14-2007, 06:11 PM
PBMW is on a distinguished road
My 2000 mini is doing this now. Throws a 217 X Phasing error at startup. then when you clear that, when you go to home the machine, it throws a 103 error.
My CNC guy is comming Monday.
Teh machine has 11,000 hours of power on time nad 3500 run hours.
I'm gettin a little tired of repairing Haas stuff!!
Old 04-16-2007, 08:19 AM
superrat's Avatar
well, it's been almost 3 weeks and it's still running and no more errors. we've had it running alot lately, so we stopped and took a minute to clean it up pretty good and it's been running ok. i suppose we'll keep going till it happens again...
thanks --phil
Old 04-16-2007, 11:14 AM
Originally Posted by superrat View Post
..it's been running ok. i suppose we'll keep going till it happens again...
thanks --phil
Good philosophy, saves on the stress levels . We had a malfunction on the dorr interlock switch on an old MiniMill about five years ago. I took it off, rapped it sharply on a bench a few times and put it back. No problems since then; you just have to teach them they will get a cuff about the ears if they act up.
tl-2 program integrity error and program data error alarm #'s 212 250 need help CNChelp Haas Mills 12 03-14-2010 08:19 PM
434 servo alarm: Z axis detect error padobranac Fanuc 19 07-30-2007 03:12 PM
Servo drive / Servo Amplifier Ken_Shea Servo Motors and Drives 9 07-10-2007 05:12 PM
servo error sv003 stanman Servo Drives 1 12-06-2006 07:46 AM
servo error JimS General Electronics Discussion 1 08-04-2003 09:23 PM
