Old 03-26-2007, 11:13 AM
1ctoolfool's Avatar
1ctoolfool is on a distinguished road
beep too loud
the beep on my control whenever you push a button just got about twice as loud for no reason i can see.
is there a setting for this?
Old 03-26-2007, 11:30 AM
pit202 is on a distinguished road
if I understand you correctly , the loudness of this beeper you can set up manualy , locate the beeper under the controll pendant ( black wheel ) and rotate it.
Old 03-26-2007, 11:37 AM
1ctoolfool's Avatar
I never would have found this, thank you very much.
I accidentally bumped it when reaching in the tray.
Is this in the instruction manual?
Thanks again
joe v
Old 03-26-2007, 11:38 AM
ltmquik's Avatar
ltmquik is on a distinguished road
The beeper is located in the area below the control panel on the top to the right. Rotate the face of the beeper to adjust the volume. Note that the volume is louder when the door is open, that is, if you still have a door. Hope this helps.
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 03-26-2007, 11:40 AM
ltmquik's Avatar
Thanks again
joe v
See my response below. Yes it is in the manual. Should be in the area that has diagrams of the control panel with descriptions and functions of the individual items of the control panel.
Jeff Lange
Silencing a loud air compressor wisp Mechanical Calculations/Engineering Design 17 08-16-2010 04:14 PM
V2XT Head Rebuilt= runs hot & loud v488 Bridgeport and Hardinge Mills 14 06-21-2006 07:35 AM
How Loud is a router? CNC Brute DIY-CNC Router Table Machines 19 12-10-2003 07:25 PM
Thinking out loud kong Machine Problems, Solutions , Wireless DNC, serial port 25 04-29-2003 08:58 AM
