I am in the process of ordering a VF2-SS (new).: Super Speed 30" x 16" x 20" (762 x 406 x 508mm) (xyz), 30-hp (22.4kw) 12,000 rpm, inline direct drive, 24 tool high speed side-mount tool changer, 1400 ipm (35.5m/min) rapids, USB port, 1MB, rigid tapping, 55 gallon (208 liter) flood coolant system. I have added the following options to the standard machine: AAG1 - Auto Air Gun CC - Chip Auger HSM - High-Speed Machining with Look-Ahead Any thoughts on the following options/accessories: Visual Quick Code Probing System Programmable Coolant Nozzle Early power failure detection module. Additionally, I will be getting a Phase Perfect DPC30, Rotary Screw Compressor, and an Air Dryer. On the issues of compressers and Air dryers, any suggestions on brands and vendors? Thanks, TKBuisan |
| TK, Nice set up. On the VQC, any new machine comes with 200 hours free trial, same with HSM which will likely be needed if doing a lot of 3D work. I would not purchase it until you see you will be using it then it just needs turned on. On the Programmable nozzle I would think that would be a real help if you desire not to baby sit each cut. I do not know how about the early detection power failure mode option or cost but first impressions seem like a very little needed option. I guess it may be like insurance, could come in mighty handy. Wow 55 gal, my TM-1 is 5 Gal ![]() Ken |
The Sales Rep stated that the 200 Hr Usage for HSM, etc before having to pay is no longer the case. The VQC by itself is not needed, but I am interested in the probing system, but am not sure of the *real world* useability and reliability. TKBuisan. |
| The Sales Rep stated that the 200 Hr Usage for HSM, etc before having to pay is no longer the case Those cheap skates, that does not surprise me at all, perhaps it is because their options are so inexpensive ![]() Often wondered the "real World" use of a probe myself. Perhaps if doing a lot of reverse engineering but for touch off very doubtful. I hope others that do use them share some input here. Ken |
| For compressor see this thread: http://www.cnczone.com/forums/showthread.php?t=30462 The post by Nervis...that is the carrot here. Also get the memory upgrade. 1MB is not enough..especialy with High speed look ahead..you will be Glad you did.. And definitely get programmable coolant.
I might go for the memory, but I am not sure about the Programmable Coolant. The reason I skipped the memory was that I had planned on keeping a computer next to the machine. $995 buys alot of computer and disk space. As for the programmable coolant, I've not seen many machines w/ said, nor have I heard any need. I am not against learning something new. :-) TKBuisan |
| I just want to add that the HSM trial does not work on my 2 month old VF2, even though they include a stupid "free trial" card that tells you to try it out for 200 hours free. Jerks. Oh, and I chose not to get the programmable coolant, as it seems to always have problems on the VF4's that my other employer has, so I just added a couple fan spray nozzles, and they work great! |
#11
| i have that same machine you are getting the progamable coolant is a must 24 tools thats alot of standing next to the machine ajusting the flood coolant the probing system is nice but you can live with out for the first year hsm is a nice option but you dont need it for alluminum works butter in steel and you can buy it later in an upgrade the earlie power failure is a must on the west coast lots of power problems in places(i dont know were you shop is)you will go through tools if you dont get this the spindle drops at power down and if the power goes out, 10 hours into a mold that is not a good thing but this can be added after you get the machine. remember get what you need to get started then get this extras the only thing you cant add on later with that machine your getting is tsc must be factory installed and a ingersal rand comressor would do the shop nice |
#12
Yeah, it makes sense to have programmable coolant. I can skip the HSM from the get go and add it on later. The Programmable Coolant is less expensive, and seems that I would have more immediate use. I will mostly be machining aluminum and plastics (hopefully in that order). |
| Ordering a K2 3925 | GuitarEng | Commercial CNC Wood Routers | 20 | 03-01-2007 04:06 PM |
| Anybody around Brisbane/Sunshine Coast/Wide Bay area | Stevembh | Australia, New Zealand Club house | 10 | 05-03-2006 08:27 AM |
| Approximate coast to build? | Dirtbos | CNC Plasma and Waterjet Machines | 3 | 09-09-2005 02:33 PM |
| Anybody around Brisbane/Sunshine Coast/Wide Bay built or buiding a machine | Stevembh | DIY-CNC Router Table Machines | 0 | 03-28-2005 05:21 AM |
| Ordering screws | studysession | General Metalwork Discussion | 1 | 03-20-2005 09:28 AM |
