I was told when we bought our Mini Mill last year that the chip auger was not necessary. "Most people don't buy them because the machine doesn't make that many chips." That's what the manager for the local HFO told me. Yeah right!!! Some times I have to dump the ship bucket 2 times a day!!! And we only run 8 hours a day!!! My 2 cents: If you are buying a Mini Mill, and plan on using it for production, get the auger. |
We bought a Mini Mill with a chip auger and its usless. Talk about a lack of thought on its design. We machine CPM M4 and the chips are small. The chips find every seam and bunch up and then build up as the day goes on. The machine is a real pain to clean out. You can tell this was an after thought when they installed it. John |
| cleaning the chips off your machine should be done each part don't use compressed air as it will blow chips into areas of the machine you don't want chips i run 3 full size machines with no chip removal system the amount of chips i pull out each day must be around 1500 pounds depending on the material being cut |
| one tip for the mini mills buy a shop vac, works great on those small chips the only thing you have to do is put a small piece of sheet metal where the chips enter the vac to deflect the chips down and keep the chips from wearing on the filter and plastic parts |
| Mini lathe and mini mill spindle? | ZipSnipe | General Metal Working Machines | 3 | 10-15-2010 08:13 AM |
| Home-Brewed CNC Bench Mill Using Siex X2 Mini-Mill Head | fignoggle | Benchtop Machines | 18 | 05-11-2009 11:11 PM |
| chip auger at tm-1 home made | pit202 | Haas Mills | 26 | 12-10-2007 02:25 AM |
| Fabrication of chip auger | Janos | General Metal Working Machines | 2 | 01-31-2007 02:41 PM |
| Chip auger help | Janos | General Metal Working Machines | 0 | 01-29-2007 09:40 AM |
