i know this might sound like a silly question but is the purpose of coolant to keep the bit cool or chip removal from the part?right now i'm running a part and my coolant is pointed at the bottom of the bit(drill) but i have my parts lined up one right after each other and there is a lip on the part, so after it drills the first part and goes onto the second the coolant hits the part and deflects . it is still hitting the bit but not directly on it, any forseeable problems with that? |
| Coolant also lubricates the tool as well as keeps temp down and washes away chips. As far as your problem, sometimes it happens and there isnt much you can do unless you have a programable coolant nozzle option. Unless you are deep drilling or at very high speeds it shouldnt be a huge problem. I it is a large number of parts make the coolant hit it from the front or back, instead of from the side. Good luck Chuck Reamer |
| Coolant can be as much a hinderance as a help. With high speed steel you need the coolant to lubircate and flush the chips, but with carbide, it is detrimental to the tool due to thermal shock. The chipbreaker design actually uses the chip to carry the heat buildup away from the cutting edge. With a carbide drill, the coolant is used more to blow the chips out of the hole than it is used to cool the tool. I have one job that I use a .224 solid carbide drill with thru tool coolant running at 3200 RPM @.003 feed rate, 9.6 IPM, no peck, just a bullet drill. The grind on the drill produces chips instead of strings. The coolant entrance is lagging the cutting edge instead of leading it. The following cutting edge (2 flute) is actually cutting with no coolant as it is already forming its own chip,blocking the coolant flow to its cutting edge, therefore , no thermal shock. The failure of HSS is due to the cutting edge not receiving any coolant at the actual cutting point (edge) because the string produced blocks the coolant, hence, heat buildup, and failure. I am all for solid carbide Steve Last edited by Newby2; 02-16-2007 at 10:54 PM. Reason: additional info |
| On your haas you should have a port out of the spindal that you can add lock line to and make it were there is 2,3, even 4 nozzels spraying coolnt and i do recomend coolnt for drilling but i use it for about every thing exept turning 304 and milling with TiAIN end mills on stainless they just seem to work better dry
__________________ individual who perceives a solution and is willing to take command. Very often, that individual is crazy. |
Your not the only one LOL. http://www.secotools.com/template/start.asp?id=2181 With the proper Feeds and Speeds per application these last a very long time. Some with Coolant, some without Coolant.
| That is what most companies that have an "IDEA" use, LOL. Others use regular HSS or Cobalt. Carbide drills last longer, Cut Faster, and Produce more Holes per Drill. That could be a reason why the cost so much, LOL. Worth every Penny in my book. ![]() SGS tools are great too!! http://www.sgstool.com/
#10
| I only use the Seco FF1 Series Inserts for Turning. These are Cermet (Carbide/Ceramic). I have no problems with their Solid Carbide Drills though. The TP2000 Grades seem to hold up well in CR Steels too.
#11
| and i found a drill the other day that i used instead of a carbide "yeah i had to slow it down" just a little and it has doubled the carbide and it is a Nachi
#12
Sumitomo's are good in certain applications as are the other brands. What is your #1 brand of Inserts and Coolant???????
| What is the Ideal, General Purpose Car??? | HayTay | CNCzone Club House | 32 | 08-07-2006 05:07 AM |
| Trying to decide on a general purpose endmill, that will last. | phantomcow2 | General Metalwork Discussion | 12 | 07-08-2006 12:59 PM |
| Fit for the purpose (I think) | polus | DIY-CNC Router Table Machines | 4 | 05-01-2006 11:26 AM |
| Purpose | kdoney | CNC Wire Foam Cutter Machines | 1 | 01-15-2005 10:05 AM |
| dual purpose cnc router | junkmail | DIY-CNC Router Table Machines | 2 | 03-10-2004 12:01 PM |
