Old 02-16-2007, 08:22 AM
deji is on a distinguished road
Spindle direction
Hi, I am taking a class to learn about cnc. Have had a very limited time so far actually on a machine. So yesterday we were on a haas lathe doing our tool offsets. Was making about .010 cuts on this piece with various tools and teacher came over and looked at the piece and said we werent running the spindle in the right direction. So my question is a very simple one. When in MDI mode, and enter either M3 or M4, along with a speed, then push the green cycle start button, will it use the M3 or M4 setting that I told it to turn the spindle in forward or reverse? Or would it choose the spindle direction based on some other setting? I know on the control pad there are spindle buttons, fwd, reverse, stop, etc. But just want to know if you can choose the direction using M3 or M4 when in MDI mode?
Old 02-16-2007, 06:40 PM
cncatj is on a distinguished road
let me try to answer your question:
remember MDI means Manual Data Input so if you want to run your spindle
the machine need to know what speed and what direction to run ex.
s1500 m03
Old 02-17-2007, 08:18 AM
Thanks for the reply.
Old 02-17-2007, 11:51 AM
ltmquik's Avatar
ltmquik is on a distinguished road
They Let You Actually Operate The Machne?
Jeff Lange
Lightning Tool & Manufacturing, Inc.
Old 02-22-2007, 10:44 PM
Of course. How else could you learn? Would be like teaching drivers education only from a book and sending the student to take the test without ever being behind the wheel. He will probably crash. Its a fun class. Good teacher too.
Old 02-23-2007, 01:30 AM
mulcher is on a distinguished road
that machine your on is probly baged out why only .010 you should bee cutting at .12 at least to rough and .010-.050 to finnish.
Old 02-23-2007, 08:42 AM
We were just setting the x offsets when talking about .010 cut.
What the actual problem was when my parter was making a cut, he had it on the fastest jog speed and was turning the handle in spurts, because he did the same yesterday. After turning the jog down and cranking the handle smoothly, was fine.
Old 02-23-2007, 08:49 AM
ImanCarrot's Avatar
ImanCarrot is on a distinguished road
I wish you all the best only way to learn is to try and experiment. Welcome to CNC... you will be hopelessly addicted soon and require regular parts to machine on a daily basis
When you start working weekends for free that's the time to consider thereapy lol.
I love deadlines- I like the whooshing sound they make as they fly by.
Old 02-23-2007, 11:38 AM
ltmquik's Avatar
Point taken however, I think some practical knowledge of the machine and its operations would be usefull and would result in far less repair costs from crashes. Crash the Yugo then race the Ferrari.
Jeff Lange
Old 02-23-2007, 11:53 AM
HuFlungDung's Avatar
Moderator
I guess if the spindle is turning the wrong direction, .01 is about maximum depth of cut
Always think, Deji. Blind adherence to a memorized sequence is what seperates the operators from the machinists. Various lathes and certain types of lathe tooling can be set to run in either of the two possible rotational directions. So understand what you're doing when setting up the machine, and be sure that the cutting edges are opposing the direction of rotation of the work, else how will the cutting action be performed? Let that be lesson#1 in tool grinding: how will this tool be set for cutting?
A Axis and Step and Direction Spindle Setup mklb Mach Software (ArtSoft software) 6 11-27-2009 07:19 AM
BOSS6 Spindle Direction Problem - Retrofit snakebit95 Bridgeport and Hardinge Mills 7 01-02-2007 05:17 AM
End Mill direction... CW or CCW? ngr1 General Metalwork Discussion 10 01-27-2005 09:42 PM
step in what direction craftech Stepper Motors and Drives 5 10-13-2004 05:45 AM
Help get me started in the right direction! freezer DIY-CNC Router Table Machines 27 02-08-2004 10:23 PM
