Old 02-09-2007, 08:31 PM
Chuck Reamer's Avatar
Chuck Reamer is on a distinguished road
HSM Look ahead option?
I am thinking of getting the HSM look ahead option on a new VF-3, and am wondering how good it actually works. I will be mostly doing molds on the mill using a cam software. I do not want to do any finish polishing after machining.
Is the suface finish much better on 3-d surfaces?
Does it make a big difference in machining time?
If any one has any direct experience with it I would love to hear about it. Its only about $2000 extra, and I have already convinced my boss that it would probably be worth it for the type of work I will be doing.
Old 02-09-2007, 10:04 PM
nervis1 is on a distinguished road
It makes for a much smoother motion with 3d tool paths only, it does cut cycle time a bit. It did not change my profiles or pockets at all.
I just got a new VF-2 and after about a month bought the HSM, easy to install just type in a code.
You don't add anything to the G code the HSM function just runs in the background.
Old 02-15-2007, 09:15 PM
automizer's Avatar
automizer is on a distinguished road
in the new machines there is a Try Befor You Buy option for the HSM so if you want to order the machine with out you can turn on the (I think 100 hour) test and see if it makes a difference for you if so order it like Chuck Reamer did.
I'm not lazy..., I'm efficient!
HAAS GR-408
Old 02-15-2007, 10:06 PM
WITOMCIO is on a distinguished road
How much did this upgrade cost?I'm considering it too.
Old 02-15-2007, 10:21 PM
I think its around $2000 USD for the upgrade, a small price to pay if you can use it.
Thanks for the input everyone, I talked to my Haas rep and he said its a must for doing mold work.
Old 02-15-2007, 10:22 PM
Oh I remember 2200 bucks, around there. He's right you can turn it on free for 200 hrs. The instructions were included on a little card in your install kit.
Old 02-15-2007, 10:34 PM
One more question.
I have 2004 VF-2 and 2005 VF-4.
Which one would you guys recommend to be dedicated to HSM.
Old 02-17-2007, 10:51 PM
automizer's Avatar
BOTH.... It works the same for both machines but put it on the one you will be using the most, has the highest rapids higher spindle speed ect. The better of the two
HAAS GR-408
How to turn on Advange look ahead funtion? qmas99 Fanuc 4 05-03-2007 07:53 AM
Option list M-man Fanuc 2 02-05-2007 01:15 PM
Questions about EMC for VMC-Thanx ahead JR1050 LinuxCNC (formerly EMC2) 3 11-11-2006 11:07 AM
NCPlot M99 option ?? TURNER NCPlot G-Code editor / backplotter 2 01-17-2006 01:48 AM
Block look ahead bypasses M1 optional stops Paul_S Haas Mills 0 03-07-2005 11:37 PM
