Results 1 to 2 of 2
Thread: Toolroom Mill Minimum Dimensions
    Registered 1ctoolfool's Avatar
    Jan 2004
    KY
    Can someone with a toolroom mill please measure the minimum width and height from the front?
    We have a situation here where someone ordered a TM1-P and there is going to be an issue getting it thru the door.
    Now they are talking about disassembling it, I assume they mean taking off the enclosure.
    I just need to know how big it is going to be when everything that can be removed is removed. The Haas website kind of shows the "max" dimensions, I need to know the minimum possible opening without doing something drastic like taking off the control box.
    Joe V.
    Aug 2005
    On my TM-1, the best it looks like is to remove the front chip pan, and take it thru sideways. the dimenson is the same if the table is set fairly center and the front of the machine goes thru the door first. looks to be 58"-60" either way.
  1. ABOUT HAAS Toolroom mill 1H
    By marto74 in forum Haas Mills
    Last Post: 09-12-2009, 02:06 PM
  2. ToolRoom Mill/Mini Mill
    By StampCraft in forum Haas Mills
    Last Post: 01-07-2008, 01:02 AM
  3. FS: 2006 Haas TM-1 Toolroom Mill
    By Edster in forum Haas Mills
    Last Post: 01-22-2007, 10:20 AM
  4. DM 45 AJAXCNC Toolroom Mill ?'s
    By Ben Colby in forum AjaxCNC Control Products
    Last Post: 08-25-2006, 04:03 PM
  5. Replies: 5
    Last Post: 04-12-2005, 04:40 AM
