Old 02-02-2007, 07:42 AM
renglish is on a distinguished road
Question Using 3d Coordinate Conversion On A Vf4
Hey All, I Talked To Mike Lynch About Creating A Tilted Toolpath In Z Plane Using A Adjustable Anglehead, He Told Me About Coordinate Conversion On The Machine. Has Anyone Ever Used It,and If So Could Give Me Some Ideas.
Old 02-02-2007, 10:13 AM
Haas has Coordinate Rotation and Scaling as an option but this works in X and Y. What do you mean by Coordinate Conversion?
Old 02-02-2007, 10:55 AM
Basically Im Using An Alberti Angle Head Tilted In Z 3.8 Deg.and I Want To Drill And Thread Mill Holes At That Tilt,i Have To Tilt It To The X Side, And I Also Have To Do It Tilted Left Then Rotate The Head 180deg.and Do It Right Average Amount Of Holes 240
Old 02-02-2007, 11:04 AM
Do you have a Haas manual? I have not used them but I think what you are looking for might be described under G codes 155, 161, 162, 163, 164, 165, 166, and 169.
Coordinate system problems R.thayer LinuxCNC (formerly EMC2) 0 11-19-2006 02:36 PM
Coordinate question for cam software WarrenW General CAM Discussion 11 01-09-2006 10:13 AM
Macro Work Coordinate firedog G-Code Programing 7 06-17-2005 12:03 PM
preprogrammed coordinate programming? Tristar500 General CNC (Mill and Lathe) Control Software (NC) 2 03-02-2005 08:43 AM
User coordinate system? HuFlungDung OneCNC 5 04-18-2003 09:26 PM
