Old 02-01-2007, 04:12 PM
elaganis is on a distinguished road
TL1 Haas intuitive program restarts?
Has anyone had problems when using the intuitive menu to run parts? One problem for example: I'm running an OD operation and I feed hold the machine and stop the spindle to either clear the chips or take a measurement and then I hit cycle start again. The program restarts and does not continue from were it left off. What's even stranger is that this is a sporadic problem and I'm not able to repeat all the time.
Any fixes?
-Ed
Old 02-01-2007, 04:27 PM
How old is the machine? I have a TL1 about 18 months old that gave problems on Restart with regular programs. When some later software was installed it was okay.
Another thing is to check the setting for Program Restart and whatever it is change it to the other option and see if that makes a difference. Be careful though, I did this and the program did start where I wanted it to but then when it reached the end it jumped back to the beginning and started all over.
Old 02-02-2007, 08:27 AM
The machine is two years old. I'm going to see if I can get this upgrade.
Is the setting you're talking about the one which lets you use the cycle start button as both feed hold and cycle start?
Old 02-02-2007, 08:35 AM
Originally Posted by elaganis View Post
....Is the setting you're talking about the one which lets you use the cycle start button as both feed hold and cycle start?
No that is a different one. In my manual it is the Settings section, on page 176, Setting 36 Program Restart with a description.
Old 02-02-2007, 02:06 PM
Yes. I know that one. I like to use it in the middle of a long program I'd write in MasterCam. Saves time. However it's set to OFF. I change it when required otherwise it wastes time for multiple parts.
HAAS SL20 and HAAS VF2 ProE Posts? CNC_student Post Processor Files 5 07-10-2008 02:46 PM
TL2 Intuitive Programming HELP please Greg 24 Haas Mills 4 01-05-2007 11:38 PM
Haas 2 haas serial comunication? CNCgr Haas Mills 3 12-22-2006 12:07 PM
Anyone got any basic examples of a program using a subroutine/program? Darc CamSoft Products 11 10-08-2005 11:45 PM
haas program question cncsdr Haas Mills 20 09-17-2005 12:17 AM
