| Haas VF-3 I am trying to get a program into a Haas Vf-3 from a floppy. I do not have any experience on the machine. The machine owner is the computer anti-christ so he is of no help. The file is a .cnc created from Bobcad V19. Can someone explain the operation in order to do this. I know all I am missing is something obvious. What type of file should I be using? Thanks |
| go to List Programs, insert the disk, type the exact name of the file and press F3. There's hints on the screen on most pages. 'Rekd
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I dont know about the bobcad side of things, but the file must have a % sign before and after any code. 1.Then go to the edit page of any program 2.Go to floppy directory and press enter/write 3.Highlight the program of choice off the screen and press enter/write 4. Cover eyes and ears and press cycle start! That last one is a option! Gary |
| Re: Haas VF-3
| File name beginning with letter O (not zero) followed by 5 numbers and no extension. i.e. O00001 I still fight loading files because of infrequent use but this should work. Ken Last edited by Ken_Shea; 02-19-2004 at 09:22 PM. |
| CamIam, Not sure as it has been along time since I used Bobcob, but If I remember right a ".cnc" file is not an ASCII file. It is a file formate for internal use by Bobcob. So you need to save the file as a ".Tap", which saves it as an ASCII format. Again been a long time but I think you can open the file up in Bc and then use "save as" and select .tap as the type. This is on the cam side.
| If the shop owner is"computer anti-christ " I would suggest you let that moron run his own machine and get a good job . |
| been there done that still have the tshirt. Are you putting in the program number and .nc? o05150.nc? |
| depending on the year model haas ...you can go to an existing program, hit <edit>, <F1>, <File Menu>, <disk directory>, cursor down to the file you created on floppy ...hit <write> |
#10
| Well, I got a file into the machine. Saved the file as a .tap, deleted the .tap, put in the percent signs, and all is well. Now I just need to get this Bobcad to generate useful code. Thanks to everyone. |
| HAAS SL20 and HAAS VF2 ProE Posts? | CNC_student | Post Processor Files | 5 | 07-10-2008 03:46 PM |
| Haas Lathe Reccomendations | imwllc | Haas Mills | 12 | 02-24-2006 11:18 PM |
| HAAS mini lathe | marto74 | Haas Lathes | 4 | 01-15-2004 12:55 PM |
| Searching Backwards | jonbanquer | Fadal | 11 | 07-28-2003 07:53 PM |
| HAAS Indexer Prodramming / Control | CAMmando | Haas Mills | 8 | 06-10-2003 11:22 AM |
