Results 1 to 3 of 3
Thread: stationary spindle with X,Y,Z movement
    KBW
    KBW is offline
    Oct 2003
    Decatur, Al.
    Looking for "the" answer. This is to be used on a Haas Mini Mill.
    Objective: to hold spindle stationary, but to use the X,Y and Z axis to cut with auxiliary electric spindle. Want to use post generated by SurfCam to control table movement.
    Tried: M19 "spindle orientation" inplace of Sxxxx M03.
    Movement OK till "Can" cycle line. Then error 186 basically stating spindle not turning.
    Just trying to avoid having to long hand write a program without the can cycle because in hole drilling a peck of 2 tenths for .110 deep is needed, muchless the profiling required.
    I know it's the can cycle stopping me, however I have seen a Fadal and a large Taiwanese mill do this very thing with a auxiliary spindle.
    Any help will be very much appreciated, thanks in advance.
    Registered Rekd's Avatar
    Apr 2003
    teh Debug Window
    Couple things to try; M03 S0000 or not using a canned cycle. Do the drilling long-code. (I can't say about surfcam, but I know mastercam can post long drill cycles via a switch in the post or a custom drill cycle)
    HTH
    'Rekd
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    KBW
    KBW is offline
    Oct 2003
    Decatur, Al.
    Rekd, good thought "M03 S0" doesn't work as the spindle speed minimun is 10RPMs. Mastercam is not an option I have SurfCam. I will investigate the custom drill cycle option.
  1. Sherline spindle to 30k RPM -- am I crazy?
    By nicad in forum General Metal Working Machines
    Last Post: 11-17-2010, 03:57 PM
  2. CNC Controlled Spindle motor speed control
    By gregmary in forum General Electronics Discussion
    Last Post: 02-27-2009, 08:01 PM
  3. Gilman box spindle pics
    By Swede in forum Benchtop Machines
    Last Post: 03-30-2005, 10:41 AM
  4. Stationary spindle motor using ball spline?
    By GalaticDan in forum General Metal Working Machines
    Last Post: 02-11-2005, 07:59 PM
  5. 2.2KW Allen Brad. Spindle motor?
    By GalaticDan in forum Servo Motors and Drives
    Last Post: 02-02-2005, 12:46 PM
