  #13   Ban this user!
Old 12-28-2006, 04:44 PM
dansutula is on a distinguished road
Compliments to PIT202 - Nicely Done!
Very well done PIT.
I’ve got a few questions. It appears that your tool holder is plastic, if so, what type?
Do you have a drawings or model of your design that you would be willing to sell or share? Thanks!
  #14   Ban this user!
Old 12-29-2006, 09:50 AM
pit202 is on a distinguished road
this is a normal plastic like PCV , if this helps I got only this file.
Old 12-29-2006, 10:11 AM
miljnor's Avatar
S.N.A.F.U.
miljnor is on a distinguished road
Don't have any pictures but I made a single much like yours.
Two ways I got the chip problem solved is a G4 and a M8 coolant command to wash it while above it.
And the second way is to make a cover that is spring loaded and tilts away from the tools. This is a complicated one because you have to program the column to push it out of the way before dropping in to take/leave the tool.
I believe some industrial routers have these types of covers available multiple tools.
thanks
Michael T.
"If you don't stand for something, chances are, you'll fall for anything!"
Old 12-29-2006, 10:13 AM
Al_The_Man's Avatar
Originally Posted by pit202 View Post
isn`t is possible to make thumbnails on this forum ?
You can post a JPG if within the right size, use IrfanView to resize if necessary.
  #17   Ban this user!
Old 01-02-2007, 06:20 PM
Thanks for the drawing PIT202!
It will save me a good bit of time if ever I need to make one!
  #18   Ban this user!
Old 01-08-2007, 09:11 PM
codyst is on a distinguished road
I drew up a design for a local vocational school so they had "ATC" capability on their TM1. Mine was made out of 1/4 steel plate that sat on die springs mounted to posts. The mill would feed down and barely touch the plate before unclamping. Then when it would do a pickup, it would feed down and slightly load the die springs to give positive force back into the spindle before clamping. I also had one replaceable aluminum block for positioning of the tool during the drop off and pickup. I'll do some digging and see if I can find my drawings and post them.
  #19   Ban this user!
Old 01-11-2007, 01:20 AM
RDemets is on a distinguished road
Thumbs up
codyst, we are planning to build "ATC" for our TM-1, since we are located in Belgium, the TM-1 was not aivailable with toolchanger due to CE regulations, so we are very interested in your design.
P.S. Sorry for my bad english
