Can I connect two HAAS mills to eachother through RS-232? We have a VM-2 with all the bells and whistles and a TM-1. I would like to be able to measure tools on the VM-2 tool setter and then upload the offset table to the TM-1. Can it be done? Nikolas |
| You can load the offsets onto a floppy. I suppose you could connect the two, but it might be tricky.
__________________ Matt San Diego, Ca ___ o o o_ [l_,[_____], l---L - □lllllll□- ( )_) ( )_)--)_) (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| 061221-1456 EST USA CNCgr: Set both machines to the same RS232 settings and use software handshake. Criss-cross pins 2 and 3 between the machines, and connect pin 7 to 7. No other pins need connection. The maximum baud rate will be determined by your cable length. Put the receiving machine in receive first, then send from the other. Make sure there is no DC or AC voltage difference between the two machines before connecting them together. I will suggest less than 0.25 volts. . |
I could, but then I wouldn't be able to load them into the TM-1 which doesn't have one. Of course I could put the disk in a PC and transfer to the TM-1 through the serial port.
Nikolas |
