| 5axis Help I was runnung through the parameters and found something that got my attention. Not too sure how to direct you guys to it... basically when you go to parameters then press pg down till two pages after the Baxis screw comp pages there are two lines that say 5axis TOFS-X and 5 axis TOFS-Y.
The post I use for five axis is not set up properly as far as my plus/minus for the Baxis, so I cahnged that parameter on the m/c. Basically I want to know if turning these two switches on will help this problem.
Oh yeah, it's a VF6 |
