Old 08-15-2006, 08:29 PM
PBMW is on a distinguished road
SL 10 turret problem
I was facing a piece of 3 1/4 dia 4340 about 3.0 long that came out of the chuck.
Smacked the turret and it is obviously out of wack.
I get a servo overload error if I try to index it.
So...
I have all the turret bolts out. There is a pin that engages a hole in the back of the turret that is about a half dia off...
How do I get this thing apart to get to the point that I can realign it???????
Any and all help / pointers would be very appreciated. The machine is about three weeks backlogged
Old 08-15-2006, 08:51 PM
This sounds a bit like a problem we had on our HL1. There is a cover plate on top of the housing for the servo and turret lock. Inside there is a coupling between the servo and the indexing mechanism. According to what the Haas tech told us this coupling is intended to slip if overloaded; it does not have any keyways just a split collar that clamps. When ours was realigned he loosened the coupling and indexed the turret; only the servo moved of course. Then he did something to unclamp the turret and moved it so it was at the position corresponding to where the servo was. Clamped the turret again and tightened the collar. He also did things to make the invisible axis visible; the turret servo is the A axis I think and there is a parameter to make it visible to the handle jog.
Maybe someone else can come in and give more information I have run out of what I managed to catch while watching him.
