The toolchanger on our Super MiniMill started sporadically giving alarm 115 Turret Rotate Fault but would then work fine with manual ATC FWD or REV and keep working okay for a variable period of time. The picture shows the cause; a small chip of aluminum sticking on the proximity detector for the Geneva mechanism. |
| 060718-0930 EST USA Karl_T: I believe the prox switches which are usually labeled "magnetic prox" are probably based on a sensing coil in an oscillator circuit, and the proximity of a conductive or magnetic material will change the loading on the oscillator. This load change is sensed by a threshold circuit that provides the on-off output. The load change that is sensed could be seen as a frequency change, or amplitude, or a cessation of oscillation. The later being the more likely technique. This type of prox switch will be more sensitive to magnetic, than to conductive but non-magnetic materials. If the sensor has a true magnetic field sensor, like a Hall device, then this type of unit will probably have a biasing magnet and will not be influenced by copper or aluminum. . |
| gar gave a more complete explanation than I can. The detectors respond less to aluminum than steel, the trigger distance is closer for aluminum than steel and depends more on the size of the piece of aluminum. I did some testing with the door proximity detector. I think the intermittent nature of the toolchanger fault was because the chip was 'floating' around in the drop of coolant. I have had similar faults with axis home switches, mostly the Y axis when someone just dumps a bucke of coolant into the machine through the door and splashes chips under the way covers. The moral is on a Haas always check the proximity detectors when the machine has a motion alarm. |
| Good to know about, thanks Geof.
![]() Or do you just mean on HAAS? Al.
Just Haas. And I wish they still used mechanical! No problems at all (so far) with the machines I have with mechanical switches. |
