Old 06-28-2006, 09:41 PM
Super MiniMill Vise/Rotary Changeover
We have a Super MiniMill that is used with a pair of Kurt 688 vises or a Haas HRT210 rotary with a tailstock and rotating fixtures. The vises are bolted to a subplate with dowels for alignment on the table so they are heavy. We built a hoist with a L shaped base that bolts onto three of the machine levelling screws with a vertical column made from trailer hitch receiver tubing just to the right of the machine door. An articulating arm pivots on the top of some 2" x 2" x 1/8" HS tube sliding in the receiver tube and pushed up by long stroke jack (Fig 1). The vise subplate is unbolted from the machine table, the hoist swung in and attached to a bracket bolted to the subplate between the vises (Fig 2). This allows the vises to be lifted over the door sill (the real hard part when this is done by hand) then the hoist is lowered and the vises are swung under the controller where they stay when not in use (Figs 3 & 4). The rotary lives inside the machine enclosure hanging from a turnbuckle attached to the square tube that supports the controller. With the vises gone the machine table is moved over (Fig 5), the rotary dropped down onto its mounting plate, the turnbuckle disconnected and the rotary slid forward under two front clamps and against two setscrews used for alignment (Fig 6). Two setscrews and two clamps are installed in the back of the rotary everything is finally tightened and it is ready for mounting the fixtures and tailstock. Alignment repeatability is better than +/- 0.0005" parallel with the Y axis and rotary centerline position. Total changeover time 10 to 15 minutes.
ID:	19368   Click image for larger version
ID:	19369   Click image for larger version
ID:	19370   Click image for larger version
ID:	19372   Click image for larger version
ID:	19373   Click image for larger version
Old 06-28-2006, 11:04 PM
Gold Member
Ken_Shea is on a distinguished road
Geof,
Why not just grab that 4th axis and place it on the bed manually
For some reason my Kurt 688 vise is getting heavier every year.
It is still true, necessity is the mother of invention.
Smart thinking !
Old 06-29-2006, 08:58 AM
rickyt is on a distinguished road
very neat idea, and a real time saver.
Old 06-29-2006, 05:51 PM
tobyaxis's Avatar
Moderator
tobyaxis is on a distinguished road
Thumbs up Nice work
Finally, someone with Brains. The easier the change over the faster things get done. Very nice work Geof. I tried to do this with a different machine once and got yelled at by some Manufacturing Manager. LOL, He was probibly mad because it wasn't his idea. Simplicity = Efficiency.
Toby D.
"Imagination and Memory are but one thing, but for divers considerations have divers names"
Schwarzwald
www.refractotech.com
Old 06-30-2006, 10:42 PM
automizer's Avatar
automizer is on a distinguished road
I had the chance to use this set up and having just a piece of paper with a few instructions I did this in 20mins the set up is so smooth. kind of scary bringing the 4th axis down it looks like its going to drop hard but it doesn't and the kurts swinging them out of the machine I was well away, not pair of steel toes are protecting you from those
Old 07-11-2006, 05:49 PM
hpappsguy is on a distinguished road
Had you considered using a Magnetic lift/hoist? It seems like the time spent rigging up you articulating arm would have been cost prohibitive considering the low cost of going with a magnetic lift.
Old 07-11-2006, 06:38 PM
I don't understand this. What is the magnetic lift/hoist going to be suspended from?
Old 07-11-2006, 07:22 PM
tobyaxis's Avatar
Moderator
Thumbs up Keep the Cool Stuff Comming!!!!!
Geof,
What other cool methods do you have in your shop? I like to see real shop efficiency, opposed to the rat holes I've worked in.
Toby D.
Schwarzwald
Old 07-11-2006, 07:46 PM
Originally Posted by tobyaxis
Geof,
Not exactly in the shop but I like to think it qualifies as cool.
http://www.cnczone.com/forums/showth...3&page=1&pp=15
I was also planning on showing some machine moving; we just had to snake our VF0 out and a new VF2 into its place.
Old 07-12-2006, 10:58 PM
tobyaxis's Avatar
Moderator
That is Cool . I saw that post months ago and cringed when I went back out to my shop. You have a very nice set-up. I'm still working on getting more equipment. Still need a small band saw, grinder, and a much larger lathe.
If you remember PM me when you post the VF swap. Your still keeping the VF0 right? Nice little machines that HAAS puts out. That's a CAT40 if I'm not mistaken with a 20 tool atc.
Have fun
Toby D.
Schwarzwald
  #11   Ban this user!
Old 01-02-2010, 06:58 PM
maxine is on a distinguished road
Ah I see now why you used the sub plates on this set up. Very nice, thanks for the info sir!
Maxi
2008 Haas TM-1, 2009 TL-1, 2010 SL-40, 2010 VF-8
  #12   Ban this user!
Old 01-04-2010, 07:55 AM
fastfrank is on a distinguished road
Geof
I will almost never comment with my opinion, good or bad, but that is BAD TO THE BONE!!
