Old 05-04-2006, 09:13 AM
machinist39 is on a distinguished road
Angry Spindle Orientation
I have a 1993 HAAS VF-2 it took a hard crash and now the spindle is out of orientation and I have no manuals for this machine. It doesn't have the parameter for adjustment as the newer machines we have. I was wondering if anyone has any information that might help me fix this problem?
Old 05-04-2006, 01:06 PM
wms's Avatar
wms wms is offline
Moderator
wms is on a distinguished road
This gets rather involved..
There is a indexing ring on the transmision..it is a small ring with a detent in it, that a shot pin goes into, to index and hold the spindle in orientation during tool changes..
You will have to remove spindle covers to even see this ring and to gain access to it..
Then it is a matter of resetting it to the right orientation.
If you PM me I would be more than glad to give you my phone number and walk you thru it.
Old 05-04-2006, 01:29 PM
daleman is on a distinguished road
you could try
try changing the spindle orientation parameter setting turn off the parameter lock then find the parameter for spindle orient and just change the value untill the spindle orientates to the proper position
Old 05-04-2006, 02:23 PM
wms's Avatar
wms wms is offline
Moderator
Daleman,
Older models (IE:93) did not have a orientation parameter it was done by a mechanical ring and shot pin..
Old 05-04-2006, 02:44 PM
we have a 1993 vf1 and that has the parameter setting for spindle orientation
Old 05-04-2006, 04:38 PM
wms's Avatar
wms wms is offline
Moderator
Well I can't argue with that..but my 93 VF3 made 2/93 has a mechanical spindle orientation ring and no parrameter..so maybe it was a flying change that happened some time in 93..and he did state he did not have a parameter to set the spindle orientation on his machine ..
Old 05-04-2006, 08:18 PM
Thanks for the information WMS, I removed the cover, loosen the ring and align the shot, reorientation done and now we back up making chips. Thanks again!!!!!!!!!!!!!!!!!!!
Old 05-04-2006, 08:58 PM
wms's Avatar
wms wms is offline
Moderator
No worries..Glad you back at it..
