Results 1 to 10 of 10
Thread: HRT-310 Indexer Problem
    KG7
    KG7 is offline
    Feb 2008
    First time poster. I browse occasioanlly and I am very appreciative of all the knowledge and support that gets offered and exchanged.
    Here is my problem:
    Just purchased a used HRT-310 Indexer and Controller (brush type) and everything looked good during initial testing and inspection.
    However, now the controller displays "HI LOAD" error and the servo will not operate. I removed the belt and the table spins freely ... but I can't seem to find the nature of the error.
    Any way to diagnose this problem?
    May 2004
    What happens when you run the servo with the belt removed?
    Bad servo bearing causing overload?
    http://www.kirkcon.com/
    Registered Machineit's Avatar
    Mar 2010
    Quote Originally Posted by KG7 View Post
    Here is my problem:
    How are you operating it, on the machine or with a controller? Have you set all of the parameters on the machine to match the unit?
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    KG7
    KG7 is offline
    Feb 2008
    Quote Originally Posted by Machineit View Post
    Mike
    Running it through the controller ... have not hooked it up to the machine tool yet. The curious thing is it literally worked fine one day, and then stopped working the next.
    The servo will not operate at all, even after the belt was removed.
    There was a little bit of handling, nothing abusive, involved between the last time it opertated successfully and now HI LOAD error.
    Jul 2005
    A brushed motor can draw excess current because of short cicuiting through the carbon dust from the brushes. This could be interpreted as a Hi Load by the controller. Try cleaning all the dust out of the servo motor.
    Mar 2010
    Quote Originally Posted by Geof View Post
    +1
    Apr 2007
    haas indexer
    We have several Haas Indexers, but use them on non- Haas machines. we have to use the control boxes with them. If the control box is not hooked up to the indexer, we get a high load alarm. Sounds like you may have to change a parameter in the controller.
    KG7
    KG7 is offline
    Feb 2008
    Quote Originally Posted by firecat69 View Post
    Brushes look good, minimal dust ... cleaned them up a little and re-installed. Now the high load and over load lights flash and then I get SER ERR. Still no movement from the servo motor.
    The manual suggested checking parameter 25 and making sure the brake delay is set for the highest value at 19 and it is.
    I am running through the haas controller ... not the machine tool.
    Mar 2010
    Speaking of the brake, do you have the air hooked up to it so it will release? Do you hear it release?
    Mike
    KG7
    KG7 is offline
    Feb 2008
    Mike
    I removed the belt from the servo so the brake should have no effect at all.
    1. SMW Indexer w/ MCV 500
      By molassesbros in forum OKK
      Last Post: 05-31-2012, 04:04 AM
    2. using the indexer
      By woodman08 in forum LOGILASE 9060/12080/150120 / 250120 cnc lasers
      Last Post: 03-10-2010, 05:42 PM
    3. Need Help!- Problem with indexer limit switches
      By johnhb in forum Bridgeport and Hardinge Mills
      Last Post: 04-30-2009, 02:22 PM
    4. Indexer /Anaheim Automation controller problem
      By Dave Modisette in forum Ability Systems - LPT Indexer and G-Code
      Last Post: 02-02-2009, 02:08 PM
    5. Indexer LPT - HELP!
      By CNC Pro in forum General CAM Discussion
      Last Post: 03-11-2004, 03:20 PM
