Why would you use a USB to edit a program? I only use them to transfer programs between machines and computers. If you edited on the USB, this might be part of the problem. Did you attempt several times? Did you try powering the machine down and restarting it between attempts? I have seen machines that need several seconds from time USB is inserted until the time the control recognizes it.
LinkBack URL
About LinkBacks
