Results 1 to 7 of 7
Thread: Thread size for Kitagawa B208 Chuck grease fittings?
    Mar 2012
    There are 2 grease fittings broken off on the chuck in the Haas lathe at work...I finally got the broken parts out, but what the heck threads are in the holes? I need to order new fittings, but have no idea what size they are. The threads appear to be 32 pitch, using a thread gauge. MSC doesn't even sell grease fittings with 32 pitch threads.
    They are the fittings on the outside of each part of the jaw that moves.
    Thanx!
    Jan 2007
    I believe they are metric and there tapered, we had some of ours break back in the late 90s, couldnt find any zerks to fit or the right tap so we just bought the big ones at the grainger I think it was grainger and used that thread style retapped. they worked.
    Mar 2012
    Yup, probably will just have to retap...No telling how long it's been like that. Well before I started learning how to program/run it.
    Jan 2007
    Before you do theres a company in the states that sells kitagawa parts Ohio I think, they also rebuild them. we used the long ago and they were always helpfull with very fast turn around, we sent them in a chuck that was trashed from a used machine and they rebuilt it at a very reasonable cost.
    they might be able to tell you what tap to use and hwere to get the zerks.
    Feb 2009
    Try a local auto parts store. They have metric fittings. Those master jaws at hard. Going to be tough to tap.
    Ats in so ca are a kitigawa dealer/rep now.
    Jul 2005
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    The fittings for the B208 are a metric 6.mm x .75 pitch. Kitagawa has them for $5 each but they have a $250.00 minimum order amount. McMaster has them on their website (part# 1105K16).
    Thanks,
    Ken Foulks
    1. Kitagawa HA6-8-46 Chuck and Cylinder
      By Shanghyd in forum EBAY ADS
      Last Post: 04-04-2012, 02:21 PM
    2. THK HSR grease fittings?
      By turboedgs in forum Linear and Rotary Motion
      Last Post: 11-29-2010, 10:29 AM
    3. Hiwin Rails/Grease fittings/lubrication?
      By CyborgCNC in forum Linear and Rotary Motion
      Last Post: 09-04-2009, 02:51 AM
    4. Grease fittings for Hiwin 20mm blocks
      By escott76 in forum Linear and Rotary Motion
      Last Post: 04-29-2009, 10:40 PM
    5. Need Help!- Kitagawa B-08 Power Chuck
      By HiTech in forum General Metal Working Machines
      Last Post: 02-06-2008, 10:50 AM
