Results 1 to 4 of 4
Thread: Newbie
    May 2012
    Ireland
    Newbie
    Hello all,
    I'm new here (been browsing for a while though) and 1st off can I say that I don't think I've ever come across a forum with such a huge database of topics that would be considered a niche. i'm very impressed
    Anyway, the workshop i work in at the moment has a Hass Minimill, which I've only recently revieved, it had been sitting idle for quite some time so there was a few bits to be done, the worst of which was as ye'll probably guess, clean out the coolant bed/tank. The sludge was unbelievable to say the least. That poor little pump was in an awful condition too!!
    I'll probably have loads of questions over the next few months as up to a few months ago, it had been nearly 20 years since I'd even seen a CNC machine, let alone anything else. The maching will be used for some repeat jobs and some intricate one offs too for machine parts in a fairly high volume production and packaging plant in the pharma industry. I myself am employed in the maintenance department.
    So thats the intro over.
    M.
    Registered Machineit's Avatar
    Mar 2010
    Welcome, we are standing by.
    After cleaning out the sump, I would get a good cleaner and run it through the lines for quite a while. The junk will be in all of the lines too.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    May 2012
    Ireland
    Quote Originally Posted by Machineit View Post
    Mike
    Thanks,
    yeah, I ran a gallon of water soluble jizer through it for a while and then followed that with clean water, you could eat your dinner out of it now!!
    Oct 2009
    uk
    Hope this helps, this is what i use to get me out of trouble copy and paste as a prog into your machine, its a good reference,
    O99999 (MILL PROGRAM EXAMPLES)
    (TO SEARCH WHAT YOUR LOOKING FOR TYPE IN)
    (THE RELEVANT N NUMBER THEN PRESS THE CURSOR)
    (DOWN KEY)
    (N1=SAFETY START LINE) (G40,G80,G00,ETC)
    (N2=WORK OFFSET) (G54,G55,ETC)
    (N3=TOOL CALL) (M6 T1,ETC)
    (N4=SPINDLE COMMANDS) (M03,M04,M05)
    (N5=CUTTER COMENSATION) (G40,G41,G42)
    (N6=DRILLING CYCLES) (G81,G82,G83,G73)
    (N7=BORING CYCLES) (G85,G86,G89, G76)
    (N8=TAPPING CYCLE) (G84, ETC)
    (N9=HOLE PATTERN CYCLES) (G70,G71,G72)
    (N10=CIRCULAR POCKET MILLING) (G12,G13)
    (N11=GENERAL POCKET MILLING) (G150)
    (N12=ENGRAVING CYCLE) (G47P0, G47P1)
    (N13=EXAMPLE CUTTER COMP. PROGRAMS)
    (N19=COOLANT COMMANDS) (M08,M09,ETC)
    (N23=END OF PROGRAM EXAMPLE)
    (N24=VARIOUS OTHER COMMANDS)
    (N26=SUB PROGRAM CALLS) (M97,M98)
    (N28=,C AND ,R EXPLANATION)
    N1 (*******************************)
    (SAFETY START LINE)
    (G90=ABSOLUTE CO-ORDINATE PROGRAMMNING)
    (G00=RAPID LINEAR COMMAND)
    (G40=CUTTER COMPENSATION CANCEL)
    (G80=CANNED CYCLE CANCEL)
    (G98=INITIAL POINT RETURN)
    (G17=MILL MODE)
    (G21=METRIC)
    (SAFETY START LINE)
    G90 G00 G40 G80 G98 G17 G21
    N2 (*******************************)
    (WORK OFFSET)
    (WORK OFFSETS ARE USED TO SHIFT)
    (ALL TOOLS A UNIFORM AMOUNT)
    (G54-G59) (G110-G129) (G154P1-G154P99)
    (WORK OFFSET)
    G90 G00 G54
    N3 (*******************************)
    (TOOL CHANGE SEQUENCE)
    (M09=COOLANT OFF)
    (G53 Z0=USING THE MACHINES CO-ORDINATE SYSTEM GOTO Z ZERO)
    (M05=STOP SPINDLE)
    (M01=OPTIONAL STOP)
    (T1 M06=TOOLCHANGE TO TOOL 1, CHANGE NUMBER ACCORDING TO TOOL)
    (S1250=SPINDLE SPEED TO RUN TOOL AT)
    (M03=RUN SPINDLE IN A CW DIRECTION)
    (G43=TOOL LENGTH COMPENSATION)
    (H01=MUST ALWAYS BE THE SAME AS TOOL IN USE, LENGTH OFFSET TO LOOK AT)
    (D01=MUST ALWAYS BE THE SAME AS TOOL IN USE, DIAMETER OFFSET TO LOOK AT)
    (M08=COOLANT ON)
    G90 G00 M09
    G53 Z0 M05
    M01
    T1 M06
    G90 G00 X0 Y0 S1250 M03
    G43 Z50. H01 D01 M08
    N4 (*******************************)
    (SPINDLE COMMANDS)
    (M0?=SPINDLE DIRECTION OR STOP)
    (SPINDLE SPEED)
    (SPINDLE FORWARD)
    M03 S1000
    (SPINDLE REVERSE)
    M04 S1000
    (SPINDLE STOP)
    M05
    N5 (*******************************)
    (CUTTER COMPENSATION COMMANDS)
    (CUTTER COMP LEFT)
    G41
    (CUTTER COMP RIGHT)
    G42
    (CUTTER COMP OFF)
    G40
    N6 (*******************************)
    (DRILLING CYCLES)
    (G81 DRILLING CYCLE)
    (FEED IN, RAPID RETRACT TO R)
    (Z=DRILL DEPTH)
    (R=RETRACT/RAPID TO POSITION)
    (F=FEEDRATE)
    (L0=DON'T DRILL AT PRESENT POSITION)
    G81 G98 Z-12. R3. F80. L0
    (ENTER HOLE POSITIONS)
    (G82 DRILLING CYCLE)
    (FEED IN, DWELL, RAPID RETRACT TO R)
    (G98=INTIAL POINT RETURN)
    (Z=DRILL DEPTH)
    (F=FEEDRATE)
    (P=DWELL TIME AT BOTTOM, 1.=1 SECOND)
    G82 G98 Z-2. R3. F80. P0.2 L0
    (G83 WITH Q DRILLING CYCLE)
    (PECK DRILL, RAPID RETRACT TO R EVERY Q)
    (Z=DRILL DEPTH)
    (Q=DEPTH OF EACH CUT/PECK)
    (F=FEEDRATE)
    (G83 DRILLING CYCLE WITH Q)
    G83 G98 Z-60. R3. Q6. F80. P0. L0
    (G83 WITH I,J&K DRILLING CYCLE)
    (PECK DRILL, WITH CUT DEPTH REDUCING)
    (WITH RAPID RETRACT TO R EVERY PECK)
    (Z=DRILL DEPTH)
    (I=DEPTH OF FIRST CUT/PECK)
    (J=REDUCE I BY THIS EVERY CUT/PECK)
    (K=MINIMUM CUT/PECK DEPTH)
    (F=FEEDRATE)
    (G83 DRILLING CYCLE WITH I,J & K)
    G83 G98 Z-60. R3. I15. J5. K5. F80. P0. L0
    (G73 WITH Q DRILLING CYCLE)
    (PECK DRILL, RAPID RETRACT 0.5 EVERY Q)
    (Z=DRILL DEPTH)
    (F=FEEDRATE)
    (G73 DRILLING CYCLE WITH Q)
    G73 G98 Z-25. R3. Q5. F80. P0. L0
    (G73 WITH I,J&K DRILLING CYCLE)
    (WITH RAPID RETRACT 0.5 EVERY PECK)
    (Z=DRILL DEPTH)
    (F=FEEDRATE)
    (G73 DRILLING CYCLE WITH I,J & K)
    G73 G98 Z-25. R3. I15. J3. K3. F80. P0. L0
    (G73 WITH Q&K DRILLING CYCLE)
    (WITH RAPID RETRACT TO R EVERY K)
    (Z=DRILL DEPTH)
    (R=RETARCT/RAPID TO POSITION)
    (K=RAPID RETRACT TO R EVERY)
    (F=FEEDRATE)
    (G73 DRILLING CYCLE WITH Q & K)
    G73 G98 Z-60. R3. Q6. K18. F80. P0. L0
    (CANNED CYCLE CANCEL)
    G80
    N7 (*******************************)
    (BORING CYCLES)
    (G85 BORING CYCLE)
    (FEED IN, FEED OUT TO R)
    (Z=BORE DEPTH)
    (F=FEEDRATE)
    (L0=DON'T BORE AT PRESENT POSITION)
    (G85 BORING CYCLE)
    G85 G98 Z-30. R3. F80. L0
    (G86 BORING CYCLE)
    (FEED IN, SPINDLE STOP)
    (THEN RAPID RETRACT TO R)
    (Z=BORE DEPTH)
    (F=FEEDREATE)
    (G86 BORING CYCLE)
    G86 G98 Z-30. R3. F80. L0
    (G87 BORING CYCLE)
    (FEED IN, STOP SPINDLE, MANUAL RETRACT)
    (Z=BORE DEPTH)
    (F=FEEDREATE)
    (G87 BORING CYCLE)
    G87 G98 Z-30. R3. F80. L0
    (ONCE BORE REACHES THE BOTTOM THE SPINDLE)
    (WILL STOP AND THE MACHINE WILL HAVE TO)
    (MANUALLY BE JOGGED OUT OF THE HOLE)
    (THEN CYCLE START WILL NEED TO BE PRESSED IN)
    (ORDER FOR THE PROGRAM TO CONTINUE)
    (G88 BORING CYCLE)
    (FEED IN, DWELL, MANUAL RETRACT)
    (Z=BORE DEPTH)
    (F=FEEDREATE)
    (G88 BORING CYCLE)
    G88 G98 Z-30. R3. P1. F80. L0
    (G89 BORING CYCLE)
    (FEED IN, DWELL, FEED OUT TO R)
    (Z=BORE DEPTH)
    (F=FEEDRATE)
    (G89 BORING CYCLE)
    G89 G98 Z-30. R3. P1. F80. L0
    (G76 FINE BORING CYCLE)
    (FEED IN, ORIENTATE SPINDLE)
    (SHIFT OFF BORE, RAPID RETRACT TO R)
    (SETTING 27=SHIFT DIRECTION)
    (Z=BORE DEPTH)
    (Q=SHIFT AMOUNT)
    (F=FEEDRATE)
    (I=SHIFT VALUE IN X BEFORE RETRACTING IF Q NOT SET)
    (J=SHIFT VALUE IN Y BEFORE RETRACTING IF Q NOT SET)
    (G76 BORING CYCLE)
    G76 G98 Z-30. R3. Q0.5 F80. P0. L0
    (G77 BACK BORING CYCLE)
    (Z=BORE DEPTH)
    (Q=SHIFT AMOUNT)
    (F=FEEDRATE)
    (G77 BORING CYCLE)
    G77 G98 Z-30. R3. Q0.5 F80. P0. L0
    G80
    N8 (*******************************)
    (TAPPING CYCLE)
    (INSERT J2-J9 TO RETRACT)
    (2-9 TIMES FASTER)
    (FOR L/H TAPPING CHANGE TO G74)
    (S=RPM TO TAP AT)
    (Z=TAP DEPTH)
    (R=RETRACT/RAPID TO POSITION, PITCHx3)
    (F=FEEDRATE,PITCHxRPM)
    (J=TAP RETRACT SPEED)
    (L0=DON'T TAP AT PRESENT POSITION)
    (TAPPING CYCLE)
    S700 M05
    G84 G98 Z-10. R5. F700. J1 L0
    G80
    N9 (*******************************)
    (HOLE PATTERN CYCLES)
    (PROGRAM THE MACHINE TO THE X Y)
    (POSITION OF THE BOLT CIRCLE)
    (CENTER OR START OF ANGLE LINE)
    (BOLT HOLE CIRCLE)
    (I=RADIUS OF PCD)
    (J=START ANGLE, 0 IS AT 3 O'CLOCK)
    (L=NUMBER OF HOLES REQUIRED)
    (BOLT HOLE CIRCLE)
    G70 I40. J90. L8
    (BOLT HOLE ARC)
    (I=RADIUS OF PCD)
    (J=START ANGLE,0 IS AT 3 O'CLOCK)
    (K=ANGLE BETWEEN EACH HOLE)
    (BOLT HOLE ARC)
    G71 I40. J45. K22.5 L4
    (HOLES ALONG AN ANGLE)
    (I=DISTANCE BETWEEN EACH HOLE)
    (J=ANGLE OF LINE,0 IS AT 3 O'CLOCK)
    G72 I20. J30. L6
    G80
    N10 (*******************************)
    (CIRCULAR POCKET MILLING)
    (ROUGH CIRCULAR POCKET CCW)
    (Z=POCKET DEPTH)
    (I=FIRST CIRCLE RADIUS)
    (K=RADIUS OF POCKET REQUIRED)
    (Q=CUTTER STEPOVER AMOUNT)
    (D=TOOL NUMBER USING)
    (F=FEEDRATE)
    G00 Z3. (SAFE RAPID TO POSITION)
    G13 Z-6. I12. K40. Q12. D01 F250.
    G00 Z50. (SAFE RAPID TO POSITION)
    (ROUGH CIRCULAR POCKET CW)
    (Z=POCKET DEPTH)
    (F=FEEDRATE)
    G00 Z3. (SAFE RAPID TO POSTION)
    G12 Z-6. I12. K40. Q12. D01 F250.
    (ROUGH CIRCULAR POCKET CCW STEP DOWN)
    (G91=INCREMENTAL MOVEMENT)
    (Z=DEPTH OF EACH CUT/PASS)
    (F=FEEDRATE)
    (L=NUMBER OF CUTS/PASSES TO TAKE)
    (ZxL=POCKET DEPTH)
    (ROUGH CIRCULAR POCKET CCW WITH STEP DOWN)
    G01 Z0. F700. (FEED DOWN TO TOP OF POCKET)
    G13 G91 Z-6. I12. K40. Q12. D01 F250. L3
    G90 G00 Z50. (ABSOLUTE SAFE RAPID MOVE)
    (ROUGH CIRCULAR POCKET CW STEP DOWN)
    (F=FEEDRATE)
    (ZxL=POCKET DEPTH)
    (ROUGH CIRCULAR POCKET CW WITH STEP DOWN)
    G12 G91 Z-6. I12. K40. Q12. D01 F250. L3
    (FINISH CIRCULAR POCKET CCW)
    (Z=POCKET DEPTH)
    (I=RADIUS OF POCKET REQUIRED)
    (F=FEEDRATE)
    G13 Z-6. I40. D01 F250.
    (FINISH CIRCULAR POCKET CW)
    (Z=POCKET DEPTH)
    (F=FEEDRATE)
    G12 Z-6. I40. D01 F250.
    N11 (*******************************)
    (GENERAL PURPOSES POCKET MILLING)
    (CREATE POCKET PROFILE AS A PROGRAM)
    (G150 CYCLE)
    (X=START POSITION OF CUTTER IN X)
    (Y=START POSITION OF CUTTER IN Y)
    (Z=DEPTH OF POCKET REQUIRED)
    (F=FEEDRATE)
    (Q=DEPTH OF EACH CUT/PASS)
    (I=X AXIS CUTTER STEPOVER AMOUNT)
    (J=Y AXIS CUTTER STEPOVER AMOUNT)
    (K=MATERIAL TO LEAVE FOR FINISH CUT/PASS)
    (P=PROGRAM NUMBER WHERE PROFILE IS SAVED)
    (DELETE I OR J IN THE LINE BELOW)
    (DEPENDING ON WHAT WAY THE)
    (CUTTER IS GOING, I=X & J=Y)
    (DELETE G41 OR G42 IN THE LINE BELOW)
    (CUTTER IS GOING, G41=LEFT & G42=RIGHT)
    (POCKET MILLING)
    G150 X0 Y0 Z0 F0 R0 Q0 I0 J0 K0 P0 D01 G41 G42
    G00 G40 Z50. (CUTTER COMP OFF, SAFE RAPID TO POSITION)
    N12 (*******************************)
    (ENGRAVING CYCLES)
    (LITERAL STRING ENGRAVING CYCLE)
    (TEXT TO ENGRAVE WITHIN BRACKETS)
    (I=ANGLE OF ROTATION TO ENGRAVE ON)
    (J=SCALING FACTOR, SIZE OF ENGRAVING)
    (X=START POSITION OF ENGRAVING IN X)
    (Y=START POSITION OF ENGRAVING IN Y)
    (Z=ENGRAVING DEPTH)
    (F=FEEDRATE WHILE ENGRAVING)
    (E=FEEDRATE WHILE PLUNGING IN)
    G47 P0 (TEXT TO ENGRAVE) I0. J5. X0 Y0 Z-0.2 R1. F200. E50.
    (SEQUENTIAL NUMBER ENGRAVING CYCLE)
    (Z=ENGRAVING DEPTH)
    G47 P1 (SERIAL No. ####) I0 J5. X0 Y0 Z-0.2 R1. F200. E50.
    N13 (*******************************)
    (EXAMPLE PROGRAMMING USING CUTTER COMP)
    (Y AXIS SLOT)
    G00 Z3.
    G01 Z-6. F200.
    G91
    G01 Y40. F300.
    G41 X5. D01
    (D## MUST MATCH CURRENT TOOL)
    (ENTER CUTTER RADIUS IN CURRENT D OFFSET)
    G03 X-10. R5.
    G01 Y-40.
    G03 X10. R5.
    G01 Y40.
    G01 G40 X-5.
    G90 G00 Z50.
    (X AXIS SLOT)
    G01 Z-6. F200.
    G91
    G01 X40. F300.
    G01 G41 Y-5. D01
    G03 Y10. R5.
    G01 X-40.
    G03 Y-10. R5.
    G01 X40.
    G01 G40 Y5.
    G90 G00 Z50.
    (25 DIAMETER ROUND BOSS)
    G91 G00 X-10. Y30.
    G01 G90 Z-12. F250.
    G91 G01 G41 Y-17.5 D01
    G01 X10.
    G02 J-12.5
    G01 X5.
    G01 G40 Y17.5
    G90 G00 Z50.
    (25 SQUARE BOSS)
    G91 G00 X-20. Y30.
    G01 G90 Z-12. F250.
    G01 X32.5
    G01 Y-25.
    G01 X-25.
    G01 Y30.
    G01 G40 X-17.5
    G90 G00 Z50.
    (25.0 A/F HEX BOSS)
    G91 G00 X-15. Y30.
    G01 G90 Z-12. F250.
    G01 X22.217
    G01 X7.217 Y-12.5
    G01 X-7.217 Y-12.5
    G01 X-14.434
    G01 X-7.217 Y12.5
    G01 X7.217 Y12.5
    G01 X3.
    G01 G40 Y17.5
    G90 G00 Z50.
    N19 (******************************)
    (COOLANT COMMANDS)
    (COOLANT ON)
    M08
    (COOLANT OFF)
    M09
    N23 (******************************)
    (END OF PROGRAM EXAMPLES)
    (LOAD/UNLOAD POSITION)
    G90 G00 M09
    G53 Z0 M05
    G53 X-204.2 Y0
    M30
    (HOME Z AXIS)
    G90 G00 M09
    G53 Z0 M05
    M01
    M30
    (HOME Y AND Z AXIS)
    G90 G00 M09
    G53 Z0 M05
    G53 Y0
    M01
    M30
    (END PROGRAM/RESET TO BEGINNING)
    M30
    (END PROGRAM)
    M02
    (REPEAT PROGRAM)
    M99
    N24 (******************************)
    (VARIOUS COMMANDS)
    (DWELL)
    (P=DWELL TIME 1.=1 SECOND)
    G04 P5.
    (CANNED CYCLE INITIAL POINT RETURN)
    G98
    (CANNED CYCLE R PLANE RETURN)
    G99
    (ABSOLUTE PROGRAMMING)
    G90
    (INCREMENTAL PROGRAMMING)
    G91
    (STOP PROGRAM W/O RESET)
    M00
    (OPTIONAL STOP W/O RESET)
    M01
    (GOTO BLOCK)
    (BLOCK No. N???? MUST BE IN PROGRAM)
    M99 P1234
    N26 (*******************************)
    (SUB PROGRAM CALLS)
    (LOCAL SUB PROGRAM CALL)
    (P=LOOK FOR LINE NUMBER IN CURRENT PROGRAM)
    M97 P1234
    (LOCAL SUBPROGRAM)
    (PLACE AFTER M30)
    (N=LINE NUMBER M97 IS LOOKING FOR)
    (M99=LEAVE SUB PROGRAM AND GO BACK TO MAIN PROGRAM)
    N1234
    (ENTER PROGRAM HERE)
    M99
    (EXTERNAL SUB PROGRAM CALL)
    (P=PROGRAM NUMBER TO LOOK IN MACHINE MEMORY)
    M98 P1234
    N28 (*******************************)
    (AUTOMATIC CHAMFER & RADIUS INFO)
    (AUTO RADIUS)
    (FOR AUTO RADIUS)
    (INSERT SHIFT,R AND AMOUNT)
    (ON THE END OF A G01 LINE)
    (THERE MUST BE A SUBSEQUENT)
    (MOVE FOR CALCULATION)
    (AUTO CHAMFER)
    (FOR AUTO CHAMFER)
    (INSERT SHIFT,C AND AMOUNT)
  1. Newbie- NSW
    By KMETAL in forum Australia, New Zealand Club house
    Last Post: 05-22-2010, 04:55 AM
  2. Newbie
    By miketobydog in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 09-04-2008, 05:30 AM
  3. some newbie help
    By coldpizza721 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 08-31-2008, 06:55 AM
  4. Newbie help
    By Soundstorm in forum Benchtop Machines
    Last Post: 02-07-2007, 05:10 AM
  5. Newbie
    By Closetolerance in forum Benchtop Machines
    Last Post: 12-12-2005, 04:06 PM
