Results 1 to 4 of 4
Thread: Hass Pallet changer not locating origin
    May 2012
    I have a HAAS VF-4 with a pallet changer and have been having issues when changing pallets. Pallet #1 when changing does not locate itself properly. It clamps down but when checking the origin it is off in the x direction by a few thousands every time the pallet is swapped out. Pallet #2 has no problems, it locates fine and the origin is in the same place every time.
    Has anyone else had this problem and if so what can be done to solve it?
    May 2004
    I bet you will find the Z is also off. Check all location hardware for damage, wear, and chips. I bet on the erroneous pallet it is not fully seat on alignment pins before clamping.
    http://www.kirkcon.com/
    Feb 2010
    Quote Originally Posted by txcncman View Post
    +1
    Clean all the clamping surfaces and locating pin hole.
    Registered Pondo's Avatar
    Apr 2010
    Pull the pallet off of the machine and stone the rails it sits on. Stone the rails in the machine as well. Make sure that the locating pin holes are completely clean. Clean off the small wipers on the pallets. Clean off the bottom of the clamping plate where it clamps onto the pallet - remove any embedded chips and stone off.
    If the rails are too bad, you can take the pallets off and grind them flat. I've done that once and it worked well.
    The biggest thing you can do to keep the pallets accurate is to keep the locating rails clean. Whenever I would pallet change I'd hit feed hold after the first pallet shuttled out and wipe down the rails and locating pins in the machine. We held repeatability easily within .001.
    Apparently I don't know anything, so please verify my suggestions with my wife.
  1. vf3 ss pallet changer
    By mayhem in forum Haas Mills
    Last Post: 04-25-2011, 05:45 PM
  2. Need Help!- Vibration on VF-3 w/pallet changer
    By wganders in forum Haas Mills
    Last Post: 02-24-2010, 04:38 PM
  3. Cincinnati with pallet changer
    By peterson76 in forum General Metal Working Machines
    Last Post: 01-27-2010, 08:34 AM
  4. Pallet Changer
    By MIDDEN300 in forum CNC Machining Centers
    Last Post: 09-20-2008, 09:32 AM
  5. VF-3 & Pallet Changer
    By big_mak in forum Haas Mills
    Last Post: 10-12-2007, 03:00 PM
