Page 1 of 3 123 LastLast
Results 1 to 12 of 32
Thread: Stop 4th axis from going home, EC400
    Registered 34ford's Avatar
    May 2012
    Question Stop 4th axis from going home, EC400
    I need to get the tombstone to turn 90' and then stay there till I can drill, countersink, and tap with it in that position.
    I managed to get the tombstone to turn with a A90, and drill. But when it gets through with that drill and goes to get the next tool the G28 makes it go back to 0.
    There has to be a way to get it to stay till I tell it A0.?
    Dennis
    Registered Machineit's Avatar
    Mar 2010
    Eliminate the A0. from the G28 line.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    May 2012
    Sweden
    Is it the tool change program that makes the G28 ?
    When you program M6 ?
    May 2012
    Oh I forgot to mention, there is no A0 or any A codes in my post at all.
    I have to place the A codes in manually. This old Teksoft dont do it for me.
    So what I did was put the A90 in the line with the G57 and that was all.
    I assumed it would stay at that position till I put A0 and the end of my program.
    Dennis
    Feb 2010
    Quote Originally Posted by 34ford View Post
    Do not use G28. There are other methods to position clearance in Z.
    Time to break out the manual; G28 sends all axis to the home position.
    Mar 2010
    Quote Originally Posted by haastec View Post
    When you use G28 as below, it only sends the listed axis's home.
    G00 G91 G28 Z0.;
    Per this example, only Z would return to home as in a tool change.
    Mike
    Feb 2010
    Quote Originally Posted by Machineit View Post
    G00 G91 G28 Z0.;
    Mike
    I agree 100% but I suspect that he is using just G28 by itself. My intent was to encourage him to look up how to use G28 properly.
    Perhaps maybe he could post part of his code?
    Mar 2010
    Dang, messed you up, want me to edit it?
    May 2012
    Thats the way Teksoft does just before each tool change, which works, just not now that I wanna keep this axis to stay put.
    I will take the G28's out tomorrow and see how it works.
    Dennis
    Mar 2010
    Teksoft may be trying to clear everything out of the way for a tool change, so just make sure nothing is in the way for a tool change.
    May 2012
    Yea, I will definitely make sure the tombstone is back first.
    Oh something I just thought of too. Teksoft always puts a Z0 at the end of each op and boy that is a disaster on a EC400.
    Feeds the tombstone into the spindle!
    Dennis
    Mar 2010
    Sounds like you should ask for a different post processor.
    Mike
  • Page 1 of 3 123 LastLast
    1. Newbie- Stop and home switches questions
      By coloradonewbie in forum DIY CNC Router Table Machines
      Last Post: 11-30-2009, 11:16 PM
    2. Stop Z from going home
      By DareBee in forum Fadal
      Last Post: 11-25-2009, 03:37 PM
    3. home, limit, e-stop
      By drafterman in forum General Waterjet
      Last Post: 04-12-2007, 06:46 AM
    4. Limit, Home and E Stop Switches
      By Mr.Chips in forum General Electronics Discussion
      Last Post: 01-17-2007, 10:02 AM
    5. Home switches,E-stop advise
      By jcwebb in forum Xylotex
      Last Post: 01-17-2006, 09:10 AM
