Results 1 to 3 of 3
Thread: mirrored text
    Oct 2009
    mirrored text
    Is there a setting or something to do or change. Tried engraving some text on a round part in the rotary it was programed with gibbs and rendered correctly but the actual engraving was mirrored on the part when milled. The 4th axis mirror setting is in the off position. I would think if it rendered right it should mill right?
    Registered Machineit's Avatar
    Mar 2010
    Quote Originally Posted by 9wleadfoot View Post
    Sounds like the rotary should be going the opposite direction. Like A- instead of A+ or visa-verse. Just change that.
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    Nov 2005
    Scotland
    YEs your rotary is on the wrong way round, all our machines are the same and it took 10 years to notice. Like you it was when we did some rotary engraving.
    The fix.
    Go into setting 43 A axis and change
    REV ENCODER to 0 (or 1)
    REV POWER to 0 (or 1 )
    uou will have to put the emergency stop in and I can't remember if you have to switch the paramater lock off or not but you will soon work it out.
    Graeme
  1. Problem- Gcode is mirrored
    By MugenSeiki5T in forum Mach Mill
    Last Post: 08-06-2010, 09:39 AM
  2. Mirrored: What's going on here?
    By Sheridan Basses in forum Musical Instrument Design and Construction
    Last Post: 05-09-2010, 02:00 PM
  3. Work is Mirrored???
    By keelhauled in forum Post Processor Files
    Last Post: 03-30-2009, 02:38 AM
  4. Axis is Mirrored
    By s3r4ph in forum LinuxCNC (formerly EMC2)
    Last Post: 09-23-2008, 06:21 PM
  5. Output is mirrored??
    By BobLWeiss in forum Carken Products (Deskam, DeskCNC etc)
    Last Post: 01-03-2005, 12:54 PM
