Yeah. Post the code here.
I can DNC a small sample program (actually just a rectangle motion) and it runs fine. But when I try to run the exact same program again from MEM or if I save the program and try to run it again I get a "Multiple Codes" error. The code all looks exactly the same. It is a very simple program and I see no 'multiple codes' on the same line. Any ideas?
2000 Haas VF-2 : Tormach PCNC1100 :OneCnc XR5 Pro
http://www.kirkcon.com/
Step through in Single Block and you should find the multiple. It will be there but sometimes ones eyes slide over it.
FOUND IT!
I was concentrating so much on the program that I overlooked the program name itself.![]()
Thanks!
*ding ding*
