Page 1 of 2 12 LastLast
Results 1 to 12 of 20
Thread: Not Another Offset Question
    Jan 2006
    Ok... I lied. It IS another stupid offset question
    Go easy on me.. I'm still learning but I just can not get my head around the way HAAS handles the Z offset.
    I'm only familiar with the Mach software where you loaded your tool into the holder, touched the tool to your work, & clicked Z zero (or something like that). I've been reading for three days and all of the instructions that I have seen for the HAAS require you to add or subtract the position in one line from the offset number in another line... or something like that. Everyone says never use the 'part zero set' for the Z or you will crash. Why is that? What am I missing?
    I figure it is cheaper to ask here than break a few tools trying to learn what everyone else seems to already know.
    Thanks in advance!
    2000 Haas VF-2 : Tormach PCNC1100 :OneCnc XR5 Pro
    Jul 2005
    You have been reading the wrong stuff.
    Here is the sequence I use (Most times):
    Push HAND JOG
    Push OFFSET
    Now you should see either TOOL OFFSET screen or the WORK ZERO OFFSET screen. You can toggle between the two by pushing OFFSET.
    Make sure there is no entry in the Z column of the WORK ZERO OFFSET screen.
    Toggle back to the TOOL OFFSET screen.
    Bring your first tool down to the part using the paper feeler gauge method.
    Check that the cursor is on the line for the tool you are touching off.
    Push TOOL OFSET MESUR. If you look at the bottom of the screen you will see Z POSITION, the value here will transfer to the line the cursor is on.
    Push NEXT TOOL. The machine will change to the next tool and at the same time set the Jog Handle speed back to .01.
    (If you push any key between TOOL OFSET MESUR and NEXT TOOL the tool change does not happen.)
    There are variations on this method if you are using a toolsetter or a reference surface but this will get you going. Ignore anyone who rants on about a more complicated method until you has this procedure down pat.
    Registered Machineit's Avatar
    Mar 2010
    Ya, just do what Geof said and jog your tool down to the part or your setting fixture. When you get it set at the height you want. Then go to the OFFSET page. Highlight the tool that you are setting and push tool offset measure. If you are using another tool then push next tool and set it the same way.
    After you have touched off all of your tools, then add you fixture height if needed. What I mean is that if you used a 4" touch-off gauge to set them, now is the time to add the gauge height to each tool, such as -4.0" and enter.
    Keep it simple until you are confident.
    Mike
    Haas VF-2, HA5C, Hardinge CHNC 1, BobCAD V23
    May 2004
    Quote Originally Posted by Machineit View Post
    Mike
    Why are you adding gage height? Are you attempting to make the tool read zero when it touches the table? If so, why?
    http://www.kirkcon.com/
    Jul 2005
    As I said above ignore both of them until I say you can read them.
    Jan 2006
    LOL!!! I think this is how most of the other posts that I was reading ended up
    Thanks Geof!!
    Ok... so I set all of my tool offsets from an empty spot on the table somewhere using your method. Now I want to load a part in the vise. How do I get the top of the part to Z0? I want to load up tool #1, bring it down to the top of my part and............
    Mar 2010
    Quote Originally Posted by txcncman View Post
    The gauge is on top of my PART!
    May 2004
    Ah. Ok. I get it. No need to change every single tool length offset though. Unless you just like pushing a lot of buttons and risking mistyping a number once in a while. Just use the work offsets to shift all.
    Registered WallyL7's Avatar
    Dec 2008
    This AGAIN???
    Attached Thumbnails Attached Thumbnails Not Another Offset Question-picard-facepalm.jpg
    Tim
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    Quote Originally Posted by partsman View Post
    This is exactly what machineit was referring to, touching your tools off a common point. It is usually unlikely to be the table because shorter tools may not be able to reach the table. Let's use the vice jaw as an example:
    Step 1: Ensure setting 64 is OFF
    Step 2: Follow Geof's steps (Using TOOL OFFSET MEAS for each tool while touching the top of the vice jaws.)
    Step 3: Take any of the tools and touch the top of the part.
    Step 4: Toggle the offset screen to the work offsets.
    Step 5: Press PART ZERO SET for the offset (G54) you would like to use.
    Step 6: Subtract the tool length (-16.000-(-18.000)=2.000)
    (For step 6, -18.000 is the distance from machine home to the top of the vice. -16.000 is the distance from machine home to the top of the part. 2.000 is the difference.)
    Thanks,
    Ken Foulks
    Jan 2006
    Thanks Ken,
    But... now we are back at doing math. It sure seems like the HAAS should have a way to do that math for you. Is there not just a button you can press to fill in that field... and if not... why not?
    Sure... 16"-18" does not leave much room for error but real world numbers like 16.036" - 18.558" leaves a lot more room for error 1)- typing those numbers into a calculator and then 2)- typing the result back into the control.
    Feb 2010
    You can do this exact same procedure with the Haas, it's just not the most efficient way if you are using the a lot of the same tools for multiple jobs.
    This is what Geof described in his first post. However, you modified what he told you and touched off an empty spot on the table. Now you just introduced a different method. (Read Geof's second post)
    BTW, there is math involved with machining, that's just the way it is.
  • Page 1 of 2 12 LastLast
    1. offset question
      By msimpson99 in forum DIY CNC Router Table Machines
      Last Post: 09-24-2010, 11:52 PM
    2. Question about part offset, G54-59
      By Sticky Racing in forum G-Code Programing
      Last Post: 12-05-2007, 10:46 PM
    3. Offset question
      By Chris64 in forum SheetCam
      Last Post: 09-09-2007, 05:01 PM
    4. Offset Question
      By John H in forum General Metalwork Discussion
      Last Post: 09-22-2006, 11:03 PM
    5. G43 Tool Offset question
      By sbrunton in forum LinuxCNC (formerly EMC2)
      Last Post: 07-20-2005, 11:53 PM
