Install the back up files for probing.
I am running a VF1 and having a problem with the attached probing macro. A new Ethernet board was installed and a software upgraded, now I have a probing cycle macro that does not work properly. It has $ outside of brackets and seems as if the Haas does no longer read the alpha numeric code. It worked fine before software upgrade. Any thoughts
http://www.kirkcon.com/
Check parameter 57:22. This should be a 1. If that parameter is enabled, try re-loading the programs.
Thanks,
Ken Foulks
