Originally Posted by
CaptainKev
At this point the MOCON board has been replaced. The Vector drive tested good on another machine and the spindle motor has been replaced. The encoder appears to be working fine. When I try to run the spindle at 300 rpm clockwise the spindle rotates very slowly counter clockwise (it looks like it's trying to orient) and the spindle load meter pegs hard in the red. There are no alarms. When I try to orient the spindle it does the same thing, but fails to orient. The load meter hovers around 110% when I try to orient. It does alarm time out. Incidentally, I disconnected the motor cabling and shut the breaker off and test ran the motor/gearbox/spindle assembly with direct 230 VAC 3 phase to make sure that it wasn't a mechanical issue. It ran fine.
Is there some kind of initiating procedure that has to be done after replacing the spindle motor, MOCON board and Vector Drive? Any help would be appreciated.
CaptainKev.
