If it is like the ones I've had, the motor is moved to add tension to the belt. I would try that first. After that you might need to adjust the worm to the worm gear. It may have lost some adjustment because of wear.
Like most indexers, it gets it's location off of the back of the motor itself, where the encoder is located. A loose pulley, belt, or gear adjustment will not be noticed by the encoder.
Mike
LinkBack URL
About LinkBacks
