Results 1 to 3 of 3
Thread: HAAS Parameter 212
    May 2012
    HAAS Parameter 212
    I have parmeter 210 and 211 set to move x & y out of the way for tool change. I need my 4th axis to move as well? I have no idea where to start? I know it is parmeter 212 but don't know what value to put in? Any help would be great
    Apr 2004
    O.C. Californa
    This should help you will need to be in Debug to get to the Raw data screen. You want page 9.
    Good Luck
    Bob
    Attached Files Attached Files
    Registered KenFoulks's Avatar
    Aug 2010
    Haas Factory Support
    All axes are controlled by encoder counts. Find the ratio for the axis you want to set and multiply by the distance you want to set.
    A Axis:
    Parameter 47: Ratio
    Parameter 212: Tool Change Offset (Encoder Counts)
    Parameter 269 bit 3: Zero Axis TC (Enables this axis to move before tool change)
    Thanks,
    Ken Foulks
  1. z axis out of bounds parameter haas
    By edthecncman in forum Fanuc
    Last Post: 07-23-2011, 01:52 AM
  2. Need Help!- haas parameter change
    By 1983CRAZYBB in forum Fanuc
    Last Post: 03-09-2011, 07:13 PM
  3. Need Help!- Rapid on X Parameter - HAAS TL-1
    By Bosarge66 in forum Haas Lathes
    Last Post: 08-11-2010, 03:44 PM
  4. Haas Parameter Settings?
    By Zak@CWS in forum Haas Mills
    Last Post: 06-11-2009, 04:29 PM
  5. Need Help!- Haas SL-10 Parameter
    By SaxorLeoj in forum Haas Lathes
    Last Post: 11-25-2008, 09:45 AM
