Results 1 to 5 of 5
Thread: Hass TM-1P Divide by zero!
    Jul 2011
    New Zealand
    Hello all,
    I set a small mold to machine overnight and came in in the morning to find it half done.
    The mill stopped roughly 1/3 of the way through the program and came up with the alarm: 178 Divide by zero...in alarm messages it says something about a parameter not being able to be set to zero and tells me to reset the machine then failing that to contact Haas (which I have done but I haven't got ahold of anyone yet). I haven't changed any parameters and I did do a reset but it didn't help.
    Its very simple mold - just a series of pockets that are all the same. I generated the G-code with SolidCAM using imachining
    It always stops on the same line of code (shown in bold below) but I can't see a reason why it should...
    Does anyone know the cause and / or a fix for this problem????
    Any help would be greatly appreciated.. I need to get this mold out the door!
    Thanks,
    Nick
    N187938 G01 X11.3149 Y2.2415
    N187940 G03 X11.3203 Y2.2364 I0.0207 J0.0169 F12.
    N187942 X11.3637 Y2.2279 I0.0324 J0.0501
    N187944 X11.4517 Y2.3072 I-0.0157 J0.1059
    N187946 X11.4529 Y2.3235 I-0.0442 J0.0115
    N187948 G01 Y2.3237
    N187950 G03 X11.4518 Y2.3284 I-0.0266 J-0.0032 F16.
    N187952 X11.4474 Y2.3369 I-0.0256 J-0.0079 F17.
    N187954 G01 X11.4435 Y2.3419
    N187956 G03 X11.4272 Y2.3437 Z-0.7844 I-0.0091 J-0.0073
    N187958 G01 X11.317 Y2.2578 F100.
    N187960 G03 X11.3151 Y2.2411 Z-0.7874 I0.0072 J-0.0092 F13.
    N187962 G01 X11.3185 Y2.2373 F12.
    N187964 G03 X11.3237 Y2.2328 I0.02 J0.0178 F14.
    N187966 X11.3565 Y2.2235 I0.0311 J0.0
    Apr 2005
    Paradise, Ca, USA
    First thing I would try is to take the line numbers completely out and see what that does, if anything. I doubt it's your problem, but it jumped out at me since I don't know anybody that uses line numbers in large programs. And when you take the line numbers out, check out how much smaller your program file is on your computer.
    May 2004
    The line a CNC control stops on is rarely the line containing the error. CNC controls use look ahead to do calculations before a particular line is actually sent to the motion side of the control. As suggested, get rid of line numbers. Also a suggestion, break the tool path up into many tool paths, that way you do restart from the beginning when an error is encountered.
    My back plot software identifies an error on:
    Either I, J is incorrect for this end point or the previous start point is incorrect for the given I, J.
    http://www.kirkcon.com/
    Jul 2011
    New Zealand
    Thanks for the tips guys... I still haven't solved the problem but I reran the path ommiting the troublesome pocket and it is machining fine. It was just one of many pockets so it shouldnt be a big deal I don't think.
    Hopefully Haas gets back to me soon with some info.
    Thanks very much for the help.
    Nick
    Apr 2005
    Paradise, Ca, USA
    I'm really reaching now, but in the past I've had 3D code post out weird and not run. Occasionally I would be able to just make a very small change to my toolpath (say, decrease the stepover by .0002") and post it that way. Sometimes it actually worked. No matter what anybody says, computers aren't perfect.
    1. Need Help!- How to divide the model into two equal parts in artcam
      By kunte in forum ArtCam Pro
      Last Post: 04-22-2012, 06:19 PM
    2. Need Help!- How to reunite a broken/divide entity?
      By 777funk in forum BobCad-Cam
      Last Post: 05-11-2011, 10:35 AM
    3. Need Help!- CNC multiply or divide 10 times what it is programmed.
      By EliseoMonteverd in forum Mazak, Mitsubishi, Mazatrol
      Last Post: 03-08-2011, 02:58 PM
    4. Stepper driver current divide
      By mtompson in forum General Electronics Discussion
      Last Post: 04-20-2008, 03:27 PM
    5. How can I divide surfaces?
      By Jim Estes in forum BobCad-Cam
      Last Post: 01-25-2007, 06:29 PM
